Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mitsubishi VS55707 turn relay click then turns off
If you leave it unplugged for a day it will stay on for appx. 2hrs then shut off. All P.S. voltages OK and the D971 Diode was replaced. When it shuts off I loose the 3.7 volt (P-ON ) signal that is used to turn on the Q971 Transistor that creates a grd. path for the power on relay. I have looked for cold soldiers, but my eyes are not great. When it does work it works great. Any help would be gratly appreciated.
Terry
  • Mevamatic Dec 21, 2007
    Also found I have a 21 error which is x-ray protect circuit. I can not find any info in my service manual on this. The d980 diode checks ok. Thanks for the idea.
    Genius:
  • 1,153 Answers
Did you check D980? more info at ctechnicians.com
Posted on Dec 21, 2007
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Light flashes on and off, and fridge does not work
Lamp loose connection?
Try using a different bulb ?
Sep 07, 2009 | Magic Chef MCWC16MCG Wine Cooler
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
I bought A 65" Mits and had it two days approx. 2hrs. of run time
check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
More information on fixing the VS55707
ok it is the main or largest circuit board in the tv
Oct 14, 2008 | Mitsubishi VS-55707 TV
No Power will not turn on WD 62525
Are there any lights indicating the Tv has power? Any relay click when you depress power button?? Try unplugging the unit for about one minute, then plug it back into power and attempt to power it up. Let me know.
Bill
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
MITSUBISHI BIG SCREEN MODEL #VS55707
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
