Question about Refrigerators
The door frame of my fridge is really hot. What
The door frame of my fridge is really hot. What is up with that?
  • 4,070 Answers
Your condenser fan, which is underneath around back behind the cardboard backing, is probably not running. It should run when the compressor runs. The compressor is also in the same area . Test the fan- http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Oct 02, 2009
Testimonial: "What a great service. Thank you, we will check it out. "
GE Profile Arctica PSS26MG freezer thawed fridge not cold sounds like running rubber on fridge door hot as where it closes between freezer & fridge
The door frame has a heater in it to stop condensation and the freezer door sticking shut with ice.
As both freezer and fridge have failed, you need to call a refrigeration engineer, as it either needs more refrigerant gas or a new thermostat, or (hopefully not), a new compressor.
Oct 23, 2015 | GE Refrigerators
Why is the door frame so hot?
the door frame also acts as the condenser for the fridge hence the heat
Sep 11, 2014 | Refrigerators
LG gc-151sa fridge works on. But door frame get hot what is this
Door frame around the freezer compartment is heated to prevent condensation around the door frame during high humidity conditions.
During times that Air Conditioning Or Heating are used in the house, the relative humidity is low and the "energy savings" switch may be turned on - that will turn the heater OFF.
WARNING: if you accumulate sweat around the door frame, you must turn the heat back on to prevent rust and damage to door gasket
Jul 21, 2014 | Refrigerators
I have a kitchen aid superba and the outside black liners are really hit what does this mean?
Transom between fridge and freezer is usually haeted to stop condensation when you open freezer door.
it shouldnt be that hot that the seal becomes soft and flexable. normally comressor should pass hot gas through condenser first to get rid of majority of heat then to go to the mullon heaters(outer frame). By this time it would be a lot cooler.
If it is too hot to touch the condenser fan is not working to cool the condenser and compressor.
Nov 21, 2012 | Refrigerators
Amana fridge side x side SKD22S2L. The Door frames are really "Hot" mainly the center frame on the side by side. I cleaned the evaporator coils and seamed to help a little but still getting hot.
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Feb 07, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Kitchenaid fridge #KSCS25INSS hot door frame
There are heaters located inside the door frame, to prevent your doors from freezing shut, and also to prevent condensation on the outside of the appliance. It sounds to me as though that is where your problem is... Hope this helps
Sep 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Side by side frame
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
211 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
