Question about GE GTS22WCP Top Freezer Refrigerator
Does make ice cubes
The ice cube maker stopped working
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fjjkf
Posted on Sep 30, 2010
Sub zero 650 slow ice maker
Hi Maureen,
Your sub-zero 650 should produce about 8 cubes every 2 hours. It sounds like the heater beneath the ice maker may be wearing out. Ice makers use a heating mechanism to warm the cubes in the mold and force them to easily eject. If the heater is failing in the back slot, it could cause the ice cube to get stuck. If this is the case, you usually need to replace the part or the entire ice maker.
It is also possible the mechanism isn't properly aligned. You could try adjusting it.
You can find two manual on FixYa here: http://www.fixya.com/support/p24667-sub_zero_650_o_bottom_freezer
Otherwise, I suggest contacting their customer service or a technician: http://www.subzero-wolf.com/contact-and-support/index.aspx
Best of Luck!
Dec 09, 2013 | Refrigerators
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
Is it true that if you remove the white box where the ice cubes fall into, that it will stop the ice cubes from being made? I am interested in temporarily stopping the ice cubes from being made (4 months...
Removing the box may stop ice making on some refrigerators but not all. Look for an on-off switch inside your ice maker. Turning it off will not only stop the cubes from forming but in some cases will also stop the freezing action so you should remove any cubes that are there or they will melt and the melt water will run out of the ice maker. If there is no on-off switch you can raise the sensor arm up or block the ice detector beam to trick the ice maker into a "full" mode. That will stop the ice making function but not the freezing function. You could also turn off the water supply to the refrigerator if you do not need the water dispenser to work when you are not making ice cubes.
Oct 16, 2009 | Refrigerators
Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
heatman101
iot47
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
Mar 18, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
GE GTS22WCP Top Freezer Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
