Question about Apple iMac G4 Desktop
THERE IS A VERY FINE VERTICAL LINE FROM TOP TO BOTTOM OF MY SCREEN. THIS CAME ON A FEW DAYS AGO AND DID NOT INVOLVE ANY NEW PROGRAMS. THE LINE HAPPENS TO BE PURPLE IN COLOR AND STARTS ABOUT 1/5 OF THE LEFT HAND EDGE.
  • 33 Answers
Your computer needs a new LCD.
Posted on Oct 02, 2009
2 Suggested Answers
  • 39 Answers
SOURCE: THERE IS A VERY FINE VERTICAL LINE FROM TOP TO
Its a hardware problem with your monitor, and it most likely won't go away. If its a laptop and its really bothering you, you can have the LCD panel replaced for $500 or more.
Posted on Sep 18, 2009
Why is there a white line across tv screen
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 13, 2014 | Sanyo DS32920 32" TV
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Vertical black line on the left side of the
it means the lcd panel is failing you will need a new one at a appox cost or 1500 dollars it is covered under warr
Dec 20, 2009 | Televison & Video
THERE IS A VERY FINE VERTICAL LINE FROM TOP TO BOTTOM OF MY SCREEN. THIS CAME ON A FEW DAYS AGO AND DID NOT INVOLVE ANY NEW PROGRAMS. THE LINE HAPPENS TO BE PURPLE IN COLOR AND STARTS ABOUT 1/5 OF THE LEFT...
Sep 18, 2009 | Apple iMac G4 Desktop
Vertical color lines on the display
this is due to fault in the screen take it to the technician
Sep 02, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
Vertical Line on Lap Top
One or both of the following:
Your signal processor is failing OR the lcd display panel itself is failing. When one fails it's prudent to replace both.
Jun 04, 2009 | Compaq Presario M2000 Notebook
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Apple iMac G4 Desktop Logo
309 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
