Question about Seiko Smart Label Printer Pro Thermal
Only printing on half the label
The printer labels were replaced but now it is printing on only half the label.
squipps
  • 204 Answers
SOURCE: zebra 2746e printer
the pressure is uneven for the roller. It needs adjusted for the same pressure to transfer the ribbon to the label evenly.
Posted on Feb 05, 2008
Dyes
  • 6 Answers
SOURCE: Intermec PC4 label printer
Your printer is not sensing the gap between two labels.Please try calibrating the printer for the gap.
Switch ON the printer while holding FEED key down, on printer start feeding label realese the FEED Key.
Printer will stop feeding paper after printing SELF TEST, Once again press FEED key for 3 seconds. Printer will enter into normal Mode.
Check now.
Posted on Aug 15, 2008
SOURCE: magicolor 2300DL 17H fatal - labels stuck in printer
This happened to me last week. A label (or part of it) has adhered to the belt inside the printer. It's an easy fix. Turn off printer and open the side door. Remove waste toner bottle. Lift blue handle in direction of arrow to 11 o'clock position to release belt unit. Carefully remove OPC drum by pressing and pulling handle as shown by little graphic (try not to leave this drum in lighted area and don't touch green drum with fingers). Next, remove two chrome thumbscrews (may have to use slotted screwdriver) on either side of belt unit, then pull out belt unit and inspect to find stuck label. You can rotate belt easily. I removed stuck label and then cleaned glue residue with Elmer's Sticky Out ( a citrus product with no solvents) and a soft cloth. Clean thoroughly and replace belt unit, replaced thumbscrews, OPC drum, and finally, the Waste Toner bottle. Close door, turn on printer and test.
Neil
Posted on Oct 09, 2008
Niraj Limbu
  • 183 Answers
SOURCE: Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Posted on Feb 24, 2009
SOURCE: Smart Label Printer 240
Check your labels. Are there black "sensor marks" on the back of each label? That's apparently how the printer lines itself up.
Posted on Apr 02, 2009
TLP 2844-Z prints half the label info on half the label
check the label megerments at driver, or reset printer to default settings. you can also print settings direcly from printer without connect with computer, if still doing than, its possible the printhead its faulty. but before replacet please run test after factory default. hope it helps. Paulo.
Mar 28, 2014 | Zebra TLP 2844-Z Thermal Label Printer
Printing half label
halp left or half right?
Try driver from www.seagullscientific.cam driver, it will help to reset to factory default., turn off and on, do the pause test and if still doing that, printhead need to be replaced.
Dec 24, 2013 | Zebra 105SL Thermal Label Printer
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
Sep 17, 2017 | Toshiba TEC Office Equipment & Supplies
I have a Z4M plus and it only prints half of the label. One half is well printed and the other half is blank. please help
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
Nov 26, 2009 | Zebra Z4Mplus Label Printer
Printing half the vertical, no matter what size label in use.
Some drivers adjust the length of the print area, regardless of the length of the label. Do calibrate the label and also verifies that the margins are zero.
Roberto Martinez
Jul 21, 2009 | Zebra Z4M Printer
Zebra 170PAX3 not printing the top half of label
If you print a power on test label, see if the print is aligned, id so, use the top of form setttings to get all the print on the label.
As far as a USB, the printer will only take RS232-422,485, and parallel, and you can add the factory Nic card or use an external print server.
Dec 08, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Seiko Smart Label Printer Pro Thermal Logo
114 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
ray gallant
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
