Question about Lexmark E332n Laser Printer
Paper Jam on uptake on Lexmark E332n
I have a number of e332n printers. After 5 years of use, many are develpping a common problem, which is a paper jam on uptake.
It APPEARS, although I can't say for certain, that this occurs before the first set of rollers.
Is this a known problem? Is there a known solution?
Thank You!
  • 320 Answers
If you remove the drawer and set your printer on its back you will see the auto compensator on the roof of the drawer cavity there are two little rubbers tires that are installed on this unit these have been known to stretch to the point of free wheeling on thier hub. ytou can put a couple of drops of super glue under the back side of these to fasten them down. also if you take an aresol contact cleaner spray it on a rag and clean the surfaces of the wheels over time they get residue buildup on them from the paper that makes them slick and they dont grab the paper very good. clean or replace these with new ones and it will fix your problem
Posted on Dec 29, 2009
Paper bail will not make contact with paper
You may have a spring missing which holds this part in place. By having your printer looked at by a certified technician they can see what the problem may be and fix it for you.
Jun 08, 2010 | Lexmark E332n Laser Printer
Resetting the PhotoConductor Count
Following are the steps that you have to follow:
1. Press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
Thanks
May 06, 2010 | Lexmark E332n Laser Printer
Lexmark E332n- Changed toner cartridge and now off alignment How do you cartridge align
It is fairly common in this model for the paper size guides in the paper tray to shift outwards, allowing the paper to skew feed as it is being fed into the printer,
Pull out your paper tray, and make sure the adjustable paper guides on the left and right sides of the tray fit up snugly to the paper in the tray.
try this, good luck.
Dec 16, 2009 | Lexmark E332n Laser Printer
We use a Lexmark E332n laser printer at work. When someone attempts to print something, the printer jams with a problem with the paper feed coming out of the tray. It essentially folds up on itself and...
try cleaning the feed wheels with a arisole electronic contact cleaner these get a glue composite build up on them and contact cleaner will remove it with out leaving behind any residue and make sure that the paper guides in the tray are not set against the paper to tightly. i have also seen these pick wheels (the rubber tire) be so loose on the shaft that they slip causing this problem.
Nov 19, 2009 | Lexmark E332n Laser Printer
Lexmark E332n won't pick up paper from tray
There are rollers inside which you can replace and they NEED to be replaced after a certain time. Part number looks like 56P1820 but i would contact the Lexmark technical support to be sure of the part number and how to order them. It's easy to install, usually it's just clips to pull it out, and you put the new one there.
Jun 10, 2009 | Lexmark E332n Laser Printer
Paper won't pick up
check the paper roller is ok or not
May 27, 2009 | Lexmark E332n Laser Printer
Lexmark E332n printer only prints half way but test page prints fully
Click on Printers & Faxes, right clisk on your printer then Properties, then Device Settings. Check the paper sizes in Form to Tray Assignment (I use A4, think USA uses letter, you Yanks do strange things)
Also check Installed Options - Printer memory (make sure it matched the installed RAM).
Make sure you have installed the correct printer driver for the version of Windows operating system.
Dec 02, 2008 | Lexmark E332n Laser Printer
Allignment
One possible cause could be -
The Form Size setting in the
printer driver is different than the
size paper that is loaded in the
tray. For example, you inserted A4
size paper into the selected tray
but did not set the Form Size to
A4.
Sep 01, 2008 | Lexmark E332n Laser Printer
Lexmark E332n Laser Printer Logo
526 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
