Question about Dryers
No heat. Gas valve is on. Drum turns ok, blower works ok, everything else seems to work including other gas appliances
    President:
  • 1,922 Answers
Either the flame sensor eye is dirty and not letting the gas valve stay open, your gas solenoid coils,or the control board are defective
Posted on Oct 02, 2009
Carrier high efficiency furnace blower not turning when thermostat set to on position
is breaker and emergency shut off on-- check ---thermostat /operating correctly--gas /valve on--thermocouple /in working order--gas valve /operating correctly---reset ,high limiter,safety 's //are correct and not popped ---fan working order ---
Oct 25, 2016 | Carrier Heating & Cooling
Turn on broiler, select hi or lo, wait, broiler won't light, no gas smell inside oven either so gas is not even flowing to the broiler element. What's wrong?
I hate to ask the obvious, but have you verified that the gas is turned on? If your main gas shutoff valve is outside, someone may have turned the valve off.... If you have other gas appliances, do they work OK? Valves can be different, but usually a valve is "on" when the handle parallels the pipe, and "off" when the handle is turned cross-wise to the pipe.
Dec 31, 2015 | GE Profile JGS968SHSS Gas Kitchen Range
Duet gas gas dryer has no heat
does the flame go on and then shut down if so make sure vent hose is clear all the way through if ok then you need to locate the blower wheel and make sure there isnt a sock jambed in it and its tight on the shaft not spinning loose they crack and are servicable.
Aug 28, 2012 | Whirlpool GGW9200L Gas Dryer
MY carrier model #58DHC with hot surface ignitor has quit working. Blower works, but no heat. If you turn the thermostat to on fan will run but no heat. Did preliminary testings with self test on printed...
If you suspect its the ignitor? The hot surface ignitor is powered by 120v. Inspect ignitors' hot surface for cracks or burnt spots. Uplug ignitor from board. Cycle heat on and verify 120v to the ignitor at the cannon plug on the board where the ignitor plugs in. If you have the voltage then replace the ignitor. If not, you'll need to verify all other circuits are working before condemning the board. Work safe and at your own risk! Hope this helps!
Mar 25, 2017 | Heating & Cooling
My mother has a Kitchenaid Superba Dryer, gas, everything seems to work, but the unit won't heat.
WELL ITS 1 OF A COUPLE OF THINGS NO HEAT KITCHEN AID USES A THERMAL FUSE IN THE BACK OF THE DRYER CHECK THAT FIRST USE A MULTI METER FOR THAT ALWAYS UNPLUG ANY APPLIANCE WHEN DOING ANY WORK ON THEM IF YOU HAVE A GLOW DOWN ON BOTTOM IT COULD BE THE FLAME SENSOR IS BAD OR GAS VALVE COILS ARE NOT LETTING THE GAS OUT OR YOUR GAS IS OFF AT MAIN FROM HOUSE GOOD LUCK GEORGE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Nov 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Maytag gas dryer -
still may be solenoids belive it or not the coils could become weak and fail to pull open valve recommend changing both at same time
Apr 26, 2008 | Hotpoint NLL113EYWO Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
