Question about Dell Inspiron 6000 Notebook
First problem: screen will not come on, no blue
1st problem: screen will not come on, no blue screen, just black screen. How to turn on?
2nd problem: Corrupted Windows/System32/Dll . . . message. Instructed by system to reinstall "set up" disk and restart by pressing "r". Did as required and screen seems to be stuck in a loop and does not respond. Is there a way to get out the loop to initiate computer off the boot disk? Restore not possible off the setup disk.
Thanks
    Scholar:
  • 92 Answers
REGISTRY PROBLEM .
REMOVE THE BATTERY FOR AWHILE, THEN RE-INSERT.
TURN ON.
THAT SHOULD ALLOW U TO GET TO THE SCREEN WHERE AT START-UP, PRESS F8 FOR TROUBLE SHOOTING OPTIONS.
PRESS F8 REPEATEDLY TIL THE BOOT OPTION SCREEN COMES UP.
YOU WILL GET A VARIETY OF OPTIONS INCLUDING LAST GOOD KNOWN CONFIGURATION.. SAFE MODE...ETC
WITH A DLL./ REGISTRY PROBLEM, THERE IS OPTION WHERE THE COMPUTER CHECKS OFF ITS PROCESSES ONE BY ONE UPON START UP.
THAT WAY IT WILL HELP YOU PINPOINT THE ISSUE AND NO HARM CAN COME TO YOUR COMPUTER OR ANY INSTALLED PROGRAMS.
YOU DO HAVE A REGISTRY PROBLEM, NO DOUBT.
GOOD LUCK.
Posted on Oct 02, 2009
    Problem Solver:
  • 19 Answers
Well, this problem happens as the result of so many things but which is more important is the solution.
system32/Dll is utility file.
the best to get this file corrected is by reloading the operating system, with these it does not mean format it no... but repair is the word i'll use.
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
Where do I find the wires that I apprently need to cross to get the check engine light to flash in order to get the codes?
Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
To clear codes (after problem has been resolved):
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the
black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals. yhis is for the 94, 92 should be the same. have a good day !!
Jun 05, 2011 | 1994 Subaru SVX
I have got one power cable going to a 2 gang switch and need to feed two seperate lights off it.
Hello.
All whites are marretted together,
  • white power - white 1st light - white 2nd light
Blacks are the return for each light, and are joined after passing through the switches,
  • black FROM 1st light - top of switch - bottom of same switch - black power AND other black from 2nd light (see next step)
  • (repeat of above) black From 2nd light - top of 2nd switch - bottom of 2nd switch - black power AND black from 1st light
NOTE: both switch blacks are marretted together to the black of power. Ground all 3 as normal to dblgang box. Total marrettes required is two (three if using one for grounds) Hope this helps. If so, please rate a four-thumbs up, Thank You.
Apr 02, 2011 | Home
Sony bravia 46" no picture no sound. Green light turns on but screen remains black. When i press input or menu still nothing.
SAME PROBLEM 2nd TIME ROUND 1st TIME I JUST UNPUGGED EVERYTHING FROM TV SWITCHED OFF MAINS OFF THEN PLUGGED MAINS IN AND TURNED ON.
Jun 25, 2010 | Televison & Video
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
Jun 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Blue shadows & black screen with flashing red light
Your problem is the convergence IC's (part number STK392-110). They will need to be replaced as well as matbe a couple of burned resistors that will be right by the IC's. Due to the complexity of this repair as well as the alignment required after the parts are replaced. you may want to contact a tech. Let em know if I can be of further assistance. You can find a local tech by going to the homepage of FIXYA and inputting your zip.
Dec 22, 2008 | Televison & Video
Mp610 blue/black screen
Hi there
If the problem occurs again , you will most probably have to replace the mainboard , as all the inputs of the unit lies on the mainboard itself.
Jan 18, 2008 | BenQ MP610 Multimedia Projector
Non stop booting
1st- Press and hold the Home button and the Sleep/Wake button at the same time.
2nd- As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery
Dec 27, 2007 | Apple iPhone Smartphone
Blue screen of death
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Jul 13, 2007 | RCA TruFlat 27F520T 27" TV
Dell Inspiron 6000 Notebook Logo
90 people viewed this question
Alun Cox
