Question about KitchenAid Dryers
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am not real handy at home.
  • 304 Answers
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Posted on Oct 02, 2009
Testimonial: "Outstanding service for a do it yourself retired Banker trying to clean out a dryer. This is a great site and I will use it and pass it along. TY...."
My bosh next 700 series I not heating to dry the clothes I checked the vent and it not clogged inside and outside. Help pls
Try to reset the thermal cutoff, but should be no reason why it should have tripped.
The actual operating procedure is
The air enters the body of the dryer through the large opening in front of the dryer
Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes).
Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse.
Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan.
The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house.
It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
Apr 20, 2012 | Bosch Dryers
Dryer won't start, replaced start button
The push-to-start button is not, in most cases, the culprit. There is a thermal fuse on the blower housing and wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Feb 10, 2011 | Kenmore Dryers
Dryer makes click when push start button but wont start
The problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Feb 01, 2011 | Kenmore Dryers
My dryer will not start. when i press the start button, the sensor light comes on and the dryer will not start.
This problem is usually due to a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Jan 27, 2011 | Whirlpool Dryers
Lights turn on but dryer wont start
The problem is likely a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Jan 23, 2011 | Kenmore Dryers
Dryer smoking up house and threw exhaust vent smells like something burnt
Hello, Well the smell is most likely from lint that is trapped in the dryer burning. The first thing you need to do is check the lint screen just inside the door. Second is to take the vent tube off of the back of the dryer and check to see if it is plugged with lint inside of the dryer. Clean out any you can see, also if the tubing inside of the dryer is most likely plugged with lint and the heating element is catching the lint on fire. If let go without cleaning this will cause a fire! I work for an appliance repair company and have seen dryers catch fire due to them being clogged with lint, you have two options; first is to clean it yourself, second is to have an appliance repair technician come to your home and clean it. The second is easier and safer but the first is cheaper but very labor intensive. I hope that answered your question and helped. Good luck!
Dec 09, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer quit running during cycle. Clothes were hot. Dryer will not start. Light works when door open & buzzer works when pushed.
Limit switch opening - most likely due to an airflow problem. Lint buildup may not be visible to you without some disassembly of the dryer. The top should fold back by removing two screws that hold the front down. The front panel should come off by removing two screws inside and possibly a few pressure clips. Check for lint buildup on the blower intake and beneath the lint filter.
Oct 28, 2010 | Kenmore Dryers
I ran the dryer without the lint filter in it and now it is noisy
First of all, You have a serious safety issue. Your dryer may catch fire. DO NOT USE YOUR DRYER.
Something went into the mechanism (yes, may be another sock), and a lot of lint went inside the dryer. The dryer needs to be cleaned by a technician. Using the dryer on its condition may cause a fire. Don't get your house burned down just to save some money doing it by yourself.
Aug 30, 2009 | LG DLE5977 Electric Dryer
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Check Filer
hmmm..no lint screen means that you have lint buildups inside the machine...check the air lines, and in and out for the vents..first.
Mar 15, 2008 | LG DLG5988 Gas Dryer
Open Questions:
Dryers Logo
141 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
