Question about Microwave Ovens
F7 error I have had several service provider come out to service the unit and no one can fix it. I can't even get whirlpool to do anything out it even with a extended warranty...I have been fighting it for three years now.
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Will run for about 18 seconds,then gives an F7 error code
>No, the service guy did none of the things you suggested.
Just as I suspected...
The "element" as it is so inaptly misnamed in the case of this warranty document, is actually the "magnetron", which should normally have an extended warranty beyond the normal 1-year (I assume) parts and labor warranty anyway.
The magnetron may be the culprit here, but a thorough check of the points on my previously posted list is in order to determine the actual cause of the problem.
Since your husband is an engineer, I would suggest that he invite a colleague over to help and to provide some backup for any heavy lifting if it should need to be removed from the wall.
Safety first after all!
You can download Kitchenaid Whirlpool owner's manuals and installation instructions here in case it needs to be taken down during troubleshooting.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
Whirlpool GMH5205XVS0 stop after few secons no heat and show A F7 signal
See my help files here: http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm There is a service bulletin here for trained service personnel which addresses the diagnosis and cure for the F7 error code in these models.
There should be a technical sheet hidden behind the controls of your microwave. If not, it is here. It is helpful.
Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Dec 01, 2017 | Whirlpool Microwave Ovens
Code f 7
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. It should cover an F7 error code.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This may help:
F7 Error Code On Microwave Ovens With Inverter Board
MODELS: GH9177XL, GH9185XL, MH9180XL, MH7155XMS, & KHHS178L for example
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Whirlpool Microwave Ovens
F7 call for service
Hi, the F7 = HV SMPS feedback error. Most of the time this is a costly microprocessor board issue but can be something as simple as a loose or broken wire.
If it is in fact new you should contact Whirlpool for warranty service. Anything you would do as a consumer will void the warranty.
Apr 02, 2011 | Whirlpool GMH5205XVB Microwave Oven
Microwave hood combination, model # MH9181XM, is not heating anything and displays an error code of F7
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 20, 2011 | Whirlpool Microwave Ovens
My new Whirlpool Microwave oven is now showing an F7 on the screen and will only turn on for 3 seconds. What should I do?
Hi and welcome to FixYa, I am Kelly.
The F7 = HV SMPS feedback error. Most of the time this is a costly microprocessor board issue but can be something as simple as a loose or broken wire.
If it is in fact new you should contact Whirlpool for warranty service. Anything you would do as a consumer will void the warranty. First make sure your microwave is registerd via this link where it says "Register your product" http://www.whirlpool.com/custserv/index.jsp
Then using that same link you can schedule service or find out where your nearest carry in service center is.
Online Service Scheduling:
https://www.whirlpool.com/service/error.jsp?country=US&lang=en&brand=WP
CONTACT WHIRLPOOL
(866) 698-2538
Mon-Fri: 8am - 10pm (EDT)
Sat: 12pm - 5pm (EDT)
email: http://www.whirlpool.com/custserv/email_form.jsp
If the unit is second hand or out of warranty please include the model number in your next response.
Thanks for choosing FixYa,
Kelly
Dec 21, 2010 | Whirlpool Microwave Ovens
Whirlpool gold Microwave stopped working displays F7 code
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 28, 2010 | Whirlpool GH5176XPT microwave Oven
My whirlpool microwave GH7208XR is displays and error saying F7 HVSMPS feedback
Jan 22, 2010 | Whirlpool GH7208XR Convection / Microwave...
F7 ERROR CODE ON GH6177XPS
This is a known problem with this unit, and whirlpool has put out a Service Flash out on this. The reason this is happening is Electrical circuit interruption between the L1 and Neutral in the microwave invert circuit. This has to be addressed by a Tech.
DrakeTech
Dec 24, 2009 | Whirlpool GH6177XPS Microwave Oven
Whirlpool Velos Microwave showing "Error F7 HV SMPS Feedback" error. What does that mean?
F7 means that the control panel is not getting feedback from the Switched Mode Power Supply (high-voltage inverter).
This could be due to a problem with the inverter or the control unit / circuit board, but it appears to be the latter in most cases.
We repair microwave control boards for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful.
You may reply back with your brand and model number if you'd like us to look into this further, or feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
http://www.microwavedisplay.com
Jun 26, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
