Question about Kenmore Dryers
Dryer 65291, burn marks
Our dryer leaves brown streaks, looks like burn marks, would it be the element or the clothes getting stuck on the drum
  • 304 Answers
The problem you describe is usually caused by a rear drum seal worn and pinching articles during part of the drum's rotation. Replacing the rear drum seal is covered in great detail at the link below. Be sure to follow all links in blue that pertain to your machine. Caution: The glue that comes with the seal is VERY sticky and messy and comes out faster than you'd like at times. Do not get it on areas and items you're not prepared to discard. It is VERY difficult to remove once dry and it dries very quickly.
Rear drum Seal replacement procedure
Posted on Oct 02, 2009
I have the calypso dryer that leaves random brown streaks on our clothes. Any suggestions
Something like this happens when one of the drum supports wears down leaving a gap between the drum & bulkhead. Clothes can get caught-up in this gap & this will cause the brown marks you see on your clothes. Open the dryer door & look around the front & rear perimeter of the drum, if you can see a gap I recommend replacing the drum rollers. If you aren't comfortable making the repair yourself, you can contact a local appliance repair shop or the manufacturer of your Calypso dryer.
Sep 28, 2017 | Dryers
My clothes are leaving the dryer with streaks (maybe 4 or 5 inches long) that appear to be burn marks. Closer inspection of the inside of the drum shows that the back "wall" of the drum is off-center...
I have the same problem and read somewhere to replace the felt belts. We have done this twice and still getting the brown marks. I have found using Goo Gone and/or Dawn dish soap and scrubbing with a brush will take most of the mark out, re-wash and HANG to dry. I'm still looking for a permanent solution to this problem, as much as these dryer cost and you can't dry white clothes???
Jun 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Brown streaks left on clothes
Not having seen this before, but my best guess would be that the piece of clothes is caught in one position and rubbing on the gasket material around the rear of the drum. Is the mark permanent?
Apr 16, 2009 | Whirlpool ET8CHEXSQ Dryer
Burn marks on clothes
problem is caused by drum seal usually the back one look closely at seal to see if there appears to be rust if so replacedrum seal ..clothes ten to rub against it while in motion causing brown streaks..would replace both front and rear just to be sure front doesn't give problems soon
Jul 26, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Dryer leaving brown streaks on clothes
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Aug 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Brown streaks on clothes
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
210 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
