Question about Jwin JD-VD130 DVD Player
DVD Tray will not open
1. Powered up DVD player.
2. I hit "eject". (tried this manually and with the remote, 2 separate times)
3. Screen says "open" but tray does not pop out.
4, If I hit "eject" again (manually or with the remote) it spins searching for a disk (I know for certain there is no disk in the player) then eventually the screen says "no disk in player".
I do hear the motor looking for the disk.
I do not hear the tray motor at all attempting to open (doesn't seem like a jam)
Any ideas?
  • 209 Answers
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Posted on Dec 21, 2007
  • Simon Zwaan
    Simon Zwaan Jan 23, 2008
    Please rate, or respond with more details.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
on Jan 19, 2016 | Denon DVD-1740 DVD Player
I Can Not Find a YAMADA DVD-7600XTV Region Unlocker
I don't know if this will work but I can atleast try to help
1) Open the disc tray.
2) While the tray is open, enter the following code with the remote's numeric pad: 2812
3) To change the region code, press the "Enter" button repeatedly. "Region 9" means all regions will be enabled.
4) Close the tray to save the desired setting.
Other Zoran Vaddis 776 based players have other options on this screen (such as Macrovision Enable/Disable) but this player only offers the region code setting (note the unused available space for other menu options).
If you press "Display" on the remote, the firmware version will be displayed.
1. Press "Eject"
2. Press "Setup"
3. Press 3x on the right "Präferenzen-Setup"
4. Press 7x Down "Land"
5. Press 1, 3, 7, 9
6. And 0 for code free
7. Press "Play"
Mar 29, 2009 | Yamada DVD-5520 DVD Player
Dvd will not eject manually or with remote tried unplugging and restarting it didn't help
It probably wasn't the best solution but it worked. I tried to jimmy open and pull out the dvd tray. When that didn't work I tried pulling the dvd out with needle nose pliers, but it did not budge. Finally I hit the eject button one last time and it worked. I hit the eject button a couple of more times and it did work. I did ruin the dvd, and haven't had a chance to play another dvd to see if it is working properly.
Nov 10, 2008 | GoVideo Go Video DVD/VCR Combo
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR eject to open the draw.
2.type 9-8-1-7. select to go through regions.
4.change to region 9 for multi region. eject to close the draw.
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
Tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Apr 19, 2008 | Philips DVP5140 DVD Player
Technical support needed can't get player to eject disc
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
Region code for Samsung DVD-V6700
1. Make sure there is no DVD in the drive. The player must be empty. Turn on the player, (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the USA ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 29334
Nov 15, 2007 | Samsung DVD-909 DVD Player
When powered up, dvd tray will open and close at will.
Maybe you can try this for setting-up the region code: 1. Open the disc tray 2. Press 9, 7, 3, 5 3. Change the region code to "1" for USA
Jun 07, 2007 | Jwin JD-VD145 DVD Player
Drive door will not open nor will it play
To open the drive door this is not a perfect fix, but it will allow to use it. After the unit is powered on: 1)Hit the "Open/Close" button 2)Wait a while (you will get the timing down) 3)Tap gently, yet briskly at the joint where the plastic faceplate connects with the metal top of the unitat the area situated around the middle of the dvd tray (area in the attached pic, that the red arrow points to)
Mar 09, 2007 | Philips DVP642 DVD Player
Jwin JD-VD130 DVD Player Logo
541 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
