Question about Toshiba Satellite M30X Notebook
Toshiba Satellite M30 - Power Problems only boots when in vertical position
This laptop will not power up when it is placed normally in horizontal position. However when the laptop is placed vertically it will run perfectly. Usually if i move the laptop the computer shuts off power instantly or has a blue screen of death.
What should i do, i am certain the problem is electrical in nature. Does the laptop require insulation or shielding in certain spots. Any suggestions?
Using a electronics lab microscope i could not find any signs of cracks or bad solder joints. All IC chips on the motherboard are good, all traces seem to be fine, no scratches either. Is something causing the motherboard to short out?
I have shown this problem to a tech and he told me that its possible that the motherboard might have a crack in it which is causing this problem.
Here's a link to a youtube video that i posted that shows what happens:
http://youtube.com/watch?v=aRWKDrvpxuM
  • 4 more comments
  • stejeda777
    stejeda777 Dec 21, 2007
    This is not a Power Jack problem since it occurs when using batter power as well.
  • stejeda777
    stejeda777 Dec 23, 2007
    I just fixed it myself! I opened up the laptop, took out the motherboard put in a small folded up piece of cardboard beneath a spot that looked like it need support. Plus in that same spot of the motherboard, everytime i bent it, the machine would boot, and everytime i let go, it would power off. The motherboard now sits on top of the piece of cardboard and is slightly bent upwards as it rest on the chassis bolted down by screws. I looks like all it needed was some strain after all, all this time i thought putting strain on motherboard was always a bad idea, but in desperate situations its worth trying in moderation, its been working 24/7. I did a full stress test today and installed Vista.
    I bet this could have been avoided if Toshiba designed the chassis properly in the first place.
  • stejeda777
    Problem solved
    Stick a piece of carboard just beneath the motherboard, just enough to support it and to bend it upwards slightly.
  • stejeda777
    This was not a shielding problem.
  • stejeda777
    stejeda777 Dec 24, 2007
    all the laptop needed was an adequate standoff on the chassis. Plus the motherboard needed some upwards strain so i placed cardboard beneath it to bend it upwards. It was actually caved in because it had no standoff what so ever in one spot.
    Watch the video.
    http://ca.youtube.com/watch?v=0mmEhw4Nc8...
  • Anonymous Nov 14, 2008
    I had the same problem. The cardboard or some type of pressure material will fix it. 100% resolved. After 4 years of intense and almost 24h work, it is fair to have a problem... But in every shop i went they tried to replace the motherboard...
TOSHIBA SATELITE M30X IT HAD LOT OF PROBLEM WITH MOTHERBNOARD PCB.I HEARED IS MANUFCATURE PROBLEM.I BOUGHT THIS LAP TOP JUST 1AND HALF YEAR AGO. NOW I CANNOT START WINDOW DOES NOT COME UP. I SEND TO TOSHIBA REPAIR SCENTRE THEY ASKING £400+ FOR REPAIR.IT IS RIDICLOUS.IT DOES NOT COVER WARRANTY NOQW. I WLL NEVER BIUY TOSHIBA AGAIN .EVEN TOSHIBA NOT HELPFUL AT ALL.CHEAP MACHINE .WHEN I BOUGHT IT I PAID OVER 1200 POUNDS FROM DIXONS dlsohal@hotmail.com
Posted on Feb 19, 2008
    Novelist:
  • 188 Answers
These are known to have a grounding problem between the speakers and mainboard - They were actually sued and eventually settled to extend the warranty. unfortunately the special extenstion program ended a few months ago and toshiba no longer will fix this. The workaround is to add shielding to it.
See this link about it:
http://www.laptoprepair101.com/laptop/2006/04/06/satellite-m35x-a70-a75-lockup-freezes-reboots/
If that doesnt fix the problem then you may have motherboard problems and at that point it would be best to part this laptop out and replace it.
Posted on Dec 21, 2007
My laptop charger is not working
Two possible causes:
1)your laptop charger is dead or malfunction
2)your laptop dc jack is loose or malfunction
If you need to turn around your charger at one position so that the laptop will charge, that means your dc jack is dead. Otherwise your laptop ac adapter should be replaced.
If you need to purchase a new toshiba charger, you may click the following link to take a look at Toshiba Satellite M30 AC Adapter:
http://www.chargerbuy.com/replacement-toshiba-satellite-m30-ac-adapter-15v-5a.html
Nov 21, 2012 | Toshiba Satellite M30-832 Laptop Charger...
CRAQUER MOT DE PASS BIOS TOSHIBA SATELLITE M30 MERCI
To reset the BIOS password read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Apr 26, 2011 | Toshiba Satellite M30-S350 Notebook
Toshiba satellite m30 bios password
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Jan 11, 2011 | Toshiba Satellite M30-S350 Notebook
Hi I only see blinkingorange LED light when power
Its seems to be very low Battery. You can remove Battery and re plug it again and check.
Also you can check it by starting your notebook with ac power on.
It problems is still there then you notebook needs to get serviced on autorized service center.
Mar 22, 2010 | Toshiba Satellite M30 Notebook
When I power on my satellite M30 it reads; load needed DLLs for kernnel. There is about one second of windows loading time before the screen shows this.
The installation may be faulty (missig or corrupted files).
Reboot. Press F8 choose Safe mode or last good configuration.
If that works , fine. If no Configure BIOS to run from CD. Insert CD and boot from it. Choose Repair or Reinstall. To repair you will have to read on Microsoft web site about Recovery console.
Hope it helps
Sep 10, 2009 | Toshiba Satellite M30 Notebook
Experts@fixya.com
its possible that you have the presentation mode turned on.
press the F5 key and the Fn key together
you might have to do this several times
this should fix the problem. Hope it helps!
Feb 01, 2009 | Toshiba Satellite M30 Notebook
Power on password for toshiba satellite m30-107
You can by shorting the CMOS/BIOS battery connector for 30 sec's with a resister pack (2.4 KOhms), but if you don't have any PC repair experience, don't try it!
"You can blow the motherboard if you get it wrong.."
I suggest you take it to a Toshiba repair shop, it will cost about $100 to have them do it for you.
May 08, 2008 | Toshiba Satellite M30 Notebook
Toshiba Satellite M30 Montior Blackout
have you tried changing the resolution, if not try this power on your laptop press F8 run in safe mode go to device manager an disable your display adapter after disabling reboot windows after rebooting go back to device manager enable display adapter and go display properties an change resolution.
Mar 15, 2008 | Toshiba Satellite M30 Notebook
Toshiba Satellite M30X Notebook Logo
298 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
