Question about Garden
My John Deere 345 dies for no apparent reason
My John Deere 345 garden tractor with 20 HP kawasaki engine dies for no apparent reason. Will start again after ten minutes or more but dies after a awhile. Any ideas?
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
  • Bruce Mommaerts
    Bruce Mommaerts Apr 14, 2017
    You might also want to check the oil levels to make sure it is topped off. If the oil is low the safety mechanism shuts down the motor when running too hot. Add anti-fouling treatment to gas to help clean.
    Sniper:
  • 197 Answers
Sounds as if the fuel cap vent is plugged or a restriction in the fuel line.Running for a while points to the fuel cap.
Posted on Nov 14, 2009
  • 403 Answers
Check out this link below for specs on your unit. Just copy and paste into your browser.
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/92_93.pdf
Check out this link for trouble shooting your unit.
http://www.johndeeretroubleshooting.com/category/john-deere-troubleshooting/
Check out this link for answers to similar problems with your 345.
http://en.allexperts.com/q/Small-Engines-Lawn-1746/John-Deere-345-surging-3.htm
Let me know if this works for you, hope this helps. Let me know if I can help you out with anything else. Also check out this link.
https://groundscare.custhelp.com/app/answers/detail/a_id/241/related/1/kw/20%20HP%20kawasaki%20engine%20dies%20for%20no%20apparent%20reason/r_id/105819
JimmyC
Posted on Oct 02, 2009
Crankcase pressure
if under warranty take back to authorized dealer, check threads or attaching method used for filler cap to be in good condition, if good check crankcase vent tube for kink or obstruction.
Sep 01, 2014 | John Deere Garden
Why does it idle up & down constantly
which v-twin ???
Kawasaki or Briggs or Kohler
but I'd suspect a dirty carb just by your question
Aug 30, 2014 | John Deere Garden
Do you have a wiring diagram for the starter on a John Deere 285 garden tractor? The old starter was removed and no wires were labeled.
Generally starters ground through the engine, so that only leaves the positive wire. That one comes from the starting solinoid. Starting solinoid gets power from the battery. Anyway these wires are the biggest ones on the machine including the negative/ground wire from the battery.
I hope this helps.
Jul 30, 2011 | John Deere Tractor Starter 285 345 2243...
On john deere 345 18 hp kawasaki liquid cooled engine .temp light starts flashing on after ten min. run time. doesn't seem to be hot and water in rad. is not boiling over. replaced radiator cap,...
Water pump gear or the water pump impeller could have failed. If its the pump and due to it being at the bottom front side of the engine it would take some time for it to boil due to the fan is always pulling air down thru the radiator and its at the very top of engine. Cool water on top and really hot coolant around the cylinder with sensor. I'm sure it's the pump.
Jul 15, 2011 | John Deere 420,1020,2010,2020,2510,2520...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
I have a John Deere GX255 Garden Tractor with a 20 HP Kawasaki engine. The engine sputters like it is running out of gas but never dies. I have changed the fuel and air filters and replaced the gas but it...
its over due for a valve adjustment its not to hard try cleaning your carb out if that dont fix it let me know and ill tell you how to do the valves
Oct 04, 2009 | Garden
Garden Logo
2,879 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
