Question about Jenn-Air JJW8527C Expressions Collection Electric Single Oven
Replace oven sensor worked for 2 weeks, today oven flashing f4 code again. Help!
What could be happening now?
  • slone Dec 21, 2007
    I was getting an F4 code, so we replaced the oven sensor. The oven worked fine until yesterday and then we started getting the F4 code again? What would be causing this to happen again?
    Thanks
I had same problem, gave F4 code, I replaced sensor and worked for a while, then gave code above about 325F and easily if oven door closure was not done "gently". Sensor measured 1096 ohms so OK. I removed control panel, unplugged connectors, especially the RTD connector at circuit board. I also unplugged keypad, but don't think that did much. Could find nothting obvious on circuit board thus reassembed system and it WORKED and at over 400F, which it has not done for a LONG time. My guess is "open" on connector. We will see how long it works, but clearly something has changed.
Posted on Sep 01, 2012
    Scholar:
  • 146 Answers
What problem are you having with the oven and are there any error codes?
Posted on Dec 21, 2007
  • Kelly Sullivan Dec 21, 2007
    The only thing that causes an F4 is an open oven temp. sensor. Something in the ERC may be causing the sensor to short and open up causing the F4. Take out the sensor and check it at room temp. you should get between 1 and 1.1K ohms. If you don't then either the ERC is causing the problem or you can check the wiring to the sensor for shorts. Also make sure whenever you replace the oven sensor that there is enough insulation in the hole it goes through so it doesn't cause heat to get to the wires. This can cause it to open or short.
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Oct 25, 2011 | Ovens
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
Whirlpool Oven has error code f4-e411
F4 Shorted oven temperature sensor Replace oven temperature sensor
Jun 11, 2011 | Ovens
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
F4 code Dacor oven
F4 means there is an open circuit in the Oven Temperature Sensor. Could be a bad sensor that needs replacing, cound be an issue with the wiring harness.
A test would be to short the sensor wire together at the sensor. the error code should change to F3. then you would know it is the sensor and not the harness.
Mar 03, 2010 | Ovens
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
Jenn-Air JJW8527C Expressions Collection Electric Single Oven Logo
103 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
