Question about Panasonic Office Equipment & Supplies
I have the E3-10 error on a Panasonic FP7713
Usually it appears when i start a copy, the sheet comes out fully blank white, and the error code appears on. It appears after the next power on again a few seconds later too. I've read that is something with the corona wire. How can I check this? Thanks a lot!
  • 149 Answers
This can be a problem with the corona wire above the drum, or the wire on the right below the drum. If you open the front door and drop the handle, under the drum you can gently put your finger in the right slot. If you feel a wire there, at least it's not broken.
This is usuaally caused by a broken wire, sometimes by dirt in the slot where the wire is, If you feel a wire there, pull out the blue plastic thingie and push it back in. you can do this with the plastic thingie above the drum too. supposedly this cleans the wire.
This code resets by opening and shutting the front door. If it comes back, it is probably broken and you need to call for service.
Posted on Oct 10, 2009
Error 3-22 panasonic FP7713
Blacking prevention film problem. try to check the image sensor in the optical section.
Jun 06, 2011 | Panasonic FP-7735 Black and White Copier
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
What does code U16 mean on Panasonic fp7713?
Did you replace the Developer unit?
I beleive the Developer unit is not installed properly
Jan 26, 2009 | Panasonic FP-7735 Black and White Copier
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Help me with a code reset panasonic fp7713
Press paper tray, zoom down key, and #1 keys simultaneously. "F1" displayed. press 8, start,then 09, start. DV will run auto for 3 min. hit stop/clear. F7-22 to clear PM count.Press stop/clear until F1 displayed. Press paper tray, zoom down, and stop/clear to exit maintenance mode.
Sep 08, 2008 | Panasonic FP-7735 Black and White Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Error code 5100
Here's what worked for me in solving this error code 5100 problem. Not only was I unable to print anything because I kept getting that code, but there was a thunking sound when the carriage stopped moving, and every time I turned the machine on it was feeding through one sheet of blank paper. I was about to go out and buy a new printer of a different brand because the Canon was unusable.
Then, fooling around with the machine's menu and settings buttons, I came across an option, I think it was in the Maintenance menu, to Restore Factory Settings. I chose that option and it asked me again if I wanted to restore the original factory settings, Yes or No. I said Yes, and immediately the printer started behaving itself. No more 5100, no more funny noises, no more blanks sheets of paper. It is back to its old self again.
That still doesn't solve the problem of spending a fortune to buy ink cartridges, but I just hooked up my old Panasonic 24-pin dot matrix printer to the printer port of my CPU (a ribbon lasts me a year and costs less than $15), and the Canon to another port, so now I can print the day-to-day stuff on the cheap dot matrix and use the Canon for the important stuff.
I don't know if restoring the factory settings will work for you, but it was the solution in my case. Hope it helps you out.
May 04, 2008 | Office Equipment & Supplies
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Panasonic 7735 problem
did you tried to restart the copy machine or to disconnect it from electricity for few minutes?
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
202 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
