Question about Mazzer Royal Grinder
The on/off switch is just continuosly rotating instead of working as usual
    President:
  • 1,618 Answers
Replace timer switch.
Posted on Oct 08, 2009
My motorola k1 continuosly raised volume every time i opened it.. and sometimes it continuosly appear a no.4 even i didnt press it..
That particular volume switch either up or down is stack.if you can dismantle the phone,just provide any screw driver that fits and release the screw (usually T6 precision screw will do).4 screw at the back panel seen obviously and 2 hidden screw located at the bottom cover in front panel (shown on that avatar of motorola logo),now release the side clips and lift up the back cover . volume key or botton is detachable,remove it and check the button if works,check and fix the volume key membrane if its bouncing or corroded,if possible to clean and align Do it.otherwise remove the volume key membrane which where it is stack.then assemble the phone and see if the volume still stack,might need a volume key membrane if damage.service center will be the last option.
Aug 02, 2011 | Motorola Mobility MoroKRZR K1m Cellular...
The motor runs to the right instead of the left, I want to know if the wiring is wrong, I bought the motor used.; or what can be the cause. I installed the motor and it works but it runs the wrong way.
Usually there is a wiring diagram inside the wiring compartment or on the side of the motor. There are internal wires that can be switched to change rotation, changing the leads coming from the outlet or power supply will make no difference.
Gary
Feb 23, 2011 | Air Tools & Compressors
Washer stops midcycle. I need to raise/lower the lid to get it started again. But if I wait too long, that doesn't work.
Would suspect you have a bad lid switch, may instead have a problem with the neutral drain of the transmission, but suspect you only need to replace the lid switch. The control panel is secured at the end caps, usually screw in back, or putty knife in base to release, control panel rotates up, remove whole cabinet if necessary, all front serviceable,(if it stops in the same spot it is in the timer though)
hope this helps
Feb 23, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My turbo wand for my bosch pressure cleaner is not working properly, it only sprays in a straight stream instead of going in a circular motion as usual how do I fix it.
That nozzle actually rotates by water pressure. This allows the 0 degree nozzle (which has the most pressure) to rotate and therefore make a larger pattern. The rotating mechanism is not turning. Most likely it is corroded. If you're handy you might be able to disassemble it and clean it. If not that try soaking in something like CLR to clean it.
Oct 08, 2010 | Bosch Garden
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Don't know how to turn off the turntable
Turntable usually automatically switch off. If it is continuosly running check the related relay driving circuit.
May 02, 2009 | Tappan TMS062E1 Microwave Oven
Relay switch
Usually starter relays are the first thng that the positive (usually red color or + sign) battery cable goes too.
Dec 22, 2008 | 2003 Hyundai Santa Fe
I have a Whirlpool AMW545 built in microwave oven. The turntable continuosly runs with the door shut when the microwave is not in use. The turntable will stop rotating if the door is opened.
the controller for the turntable is shorted out or welded its contact if its a relay. the door has safety switches that turns off the electrical connection to the turntable and magnetron once you open the door. you can trace the switch that runs the turntable. start from the power supply, goes to the door switch then to the controller before it goes to the turntable motor. i'm sure it has an electrical diagram at the inner wall of the cover.
i hope i was able to help.
Jun 27, 2008 | Whirlpool Microwave Ovens
Smasung MW7490w door/turntable problem
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
Sep 23, 2006 | Samsung SMH7159 Microwave Oven
Mazzer Royal Grinder Logo
52 people viewed this question
Top Mazzer Coffee Makers & Espresso Machines Experts
Brett Duxbury
Brett Duxbury
Bill Boyd
Mark Cheong
Mark Cheong
Level 1 Expert
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
