Question about Ovens
F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The oven was working and then stopped and started flashing an F2 error code. Now the overn won't work. What is this code for?
  • 5 more comments
  • angstuart Dec 24, 2007
    Mistakenly identified error code, actual error code is F1. I was told that the code referred to the clock/control pad. Is this correct? Does the clock/control pad come in one piece or are there multiple components I should be looking for?. Is this something that I could possibly replace on my own? Thank you for your help! angstuart@earthlink.net
  • cjoven Jan 12, 2008
    Have had the same problem TWICE - had repair once to the tune of $300 + a couple of years ago and now it is doing it again - I just flip the circuit breaker back temporarily when I want to cook with the oven. It doesn't beep for me if I am using the oven. The beeping occurs sporadically - sometimes I can go days with the oven not beeping and then it does. I really feel this is a problem the company knows about and should do a recall on.
  • Anonymous Jun 22, 2008
    Bought oven brand new 01/06/04. During holiday dinner preparation 12/25/04 my display began flashing F2 or 3, I can't remember and we eventually had to turn of the circuit breaker to get rid of it and finish our cooking. Had a repairman finally look at it 9/30/05, cost $116.60 and still to this day we get the F2's and F3's and have to play that game of turning off the circuit breaker creating a work around. Maytag sucks. I will never buy Maytag anything every again.
  • bhmhmhmhth Jun 22, 2008
    Bought maytag double oven cwe5800acb brand new 01/06/04. During holiday
    remember. Cooking stopped, beeping wouldnt so and we eventually had to
    turn it off at the circuit breaker. We got it on again and finished our
    cooking. After that time it happened again and again but
    inconsistantly. We finally had a repairman check it out on 9/30/05,
    costing $116.60. Didnt help within a month we had more F2's and F3's
    and we still to this day have to play the work around game of turning
    off the circuit breaker. Maytag sucks. I will never buy Maytag anything
    every again. I wish I would have had our old oven repaired instead of
    replacing it with this electronic ****. Oh, here is another good
    one-sometimes in the middle of the night it will begin beeping and
    flashing its little code, hours after any cooking took place.
  • Anonymous Mar 15, 2014
    what is overn manual mode in terim overns
  • Anonymous Mar 29, 2014
    want preheat top burning don't work
    oven will not heat. need to start and stop due to error code 160
    Scholar:
  • 146 Answers
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Posted on Dec 21, 2007
  • Maureen Ersek Jan 29, 2014
    replaced the relay. Didn't fix it. I ended up purchasing a used stove that is working well.
    New Friend:
UNPLUG the stove and PLUG IN again! It will resolve the issue! Good luck!!!
Posted on Mar 13, 2013
I pressed cancel and then turned the oven back on. Its working fine. I sure hope the oven isn't failing. My oven is old.
Posted on Nov 15, 2012
Before u putout $40 for a new sensor wiggle all your connections from the sensor to the control board. That solved my F2 issue. I found a parts place in Ontario that repairs controls if yours is obsolite
Posted on Oct 24, 2010
  • hookah Aug 11, 2011
    i have a maytag preforma where do i found the sensor
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
How do I replace the bottom oven element on my Maytag CWE5800?
This shouldn't be too difficult. Make sure the power is off. Remove the screws that hold the oven element in place. carefully pull the element out from the back wall without losing the wires back in the holes. Install the wire on the new element push it back in the wall. Reinstall the screws and you are set. Turn the power back on and check to make sure the oven cycles when it reaches the set temperature.
Feb 08, 2014 | Maytag Ovens
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
We have a Maytag CWE 1000 electric wall oven. It will not turn off, you hit Cancel on control panel and nothing happens. It also will start flashing other items like Broil or Conv. and beeping. If you...
As oppesed to the control itself i believe the touchpad is the colprut it plugs into the control and its a lot less expensive. The model number listed on your question,please replay with full exact model off the label which on that wall oven is either on a label by the door hinges or on the bottom or the control console between it the console and top edge of door. reply with that and i will give you the part number for that touchpad.
Gene
Aug 20, 2011 | Maytag CWE4800A Electric Single Oven
Maytag electric range, older model. What is a beeping, flashing code F2
F2- oven too hot. usually due to a bad oven temperature sensor. they sense the temperature of the oven by changing resistance, and can keep the element hot, or turn it off.
Jul 06, 2011 | Maytag Ovens
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
F2,F5,F7 message
MAYTAG
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Ovens Logo
2,980 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
