My washer is not rinsing. what is the problem how can i fix this
  • 82 Answers
The more frequently probles is door switch.
Need change door sitch.
Posted on Oct 02, 2009
Have a hotpoint aquarius wml540 that is stopping on the rinse cycle, when it stops the rinse light is on and the red lock light is flashing, is this an error code?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 07, 2015 | Hotpoint Washing Machines
Fix washing machine
TIMER
Mar 31, 2015 | Admiral Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
My washing machine mentioned above wont drain the water or preform the spin cycle process once it gets to the usual 7 minute mark. No leakage, just not drain or spin. How can I fix it?
TIMER
Mar 26, 2015 | Washing Machines
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
May 23, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Washer wont go to rinse cycle or past it
Hi, It sounds like the cold water side is still an issue. Can you rinse with hot/warm water or only cold?
Please let me know so thatI can assist you further.
Thanks
Vic
May 24, 2009 | Washing Machines
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
