Question about Baby Lock Eclipse Serger
BabyLock 5260D Main shaft "binds" after sewing only a short way.
I am having the same problem with my 5260D. The large shaft that holds the needle will not move freely up and down. It's is almost as if it is binding inside of the machine on something once the shaft gets warm. I had in to a repair person and he said that it just needed a good cleaning. I paid him to clean it, took it home and sewed about 20 inches and experienced the same problem I am reluctant to take it back to the repair person as he obviously did not know what was wrong either.
Please ... has anyone else had this happen and got it solved?
SOURCE: needle keeps hitting the pressure foot and breaking
your machine probably needs to be retimed.
Posted on Feb 20, 2009
  • 9 Answers
SOURCE: Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Posted on Jun 12, 2009
  • 20 Answers
SOURCE: Feed dog on Serger Babylock 5260D
Make sure that the presser foot dial (the silver "knob") on top of the machine is not too loose. You can adjust this w/ a nickel; tighten it all the way down & then loosen about 4 full rotations for cotton fabrics. Also make sure the Differentail feed lever is on "N". You can order a book from your local Baby Lock dealership for all models. Good Luck.
Posted on Jun 18, 2009
mohammed387
  • 1952 Answers
SOURCE: i have the basically the same problem. i was
Check the easy stuff first:
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correctly.
the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly.
the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. If that is the case.
Posted on Aug 04, 2009
trial2962
  • 107 Answers
SOURCE: Hello
Please double check the threading to this needle.
You also might take a look on ebay item 160362974035
Posted on Jan 14, 2010
I just purchased a babylock QTS428K what kind of needles do I need
Unable to find information on your particular Babylock machine. However, the manual should tell you what needles to use.
Similar models from the same era probably use the same needles.
Otherwise, a Babylock dealer would be able to help you.
http://www.sewingpartsonline.com/babylock-sewing-machine-parts-model-list.aspx
Jan 31, 2017 | Sewing Machines
Babylock serger 5260d
Make sure the loopers underneath are not broken. Are the needles
put in correct? One is suppose to be down and little more than the other- if you have them the same length that is your problem-
check your book
Mar 28, 2014 | Baby Lock Sewing Machines
The right needle on my babylock keep breaking
Perhaps the needle is not fully pushed in or not tight in the holder or has the needle plate moved and the needle is now hitting it? A bent needle will break as it hits the plate but apart from that I cannot imagine what is causing this.
May 04, 2012 | Baby Lock Sewing Machines
I would sew along for about 3 mnutes and the machine would lock up. The display would say WD. It also will change stitch length and needle placement while I am sewing. I have turned it off for about 10...
After the machine locks up, is the handwheel hard to turn? If so, you need to find where the bind is. Many times the problem is the link that connects the the upper main shaft to the needle bar. You'll have to remove the top thread tray to see the inside, and start trouble shooting.
May 13, 2011 | PfaFF Sewing Machines
Hi i have a babylock EA 605 and i know the needles go front to back threading but which way round?i dont know if i have the right needles but which way does the eye go(the oval bit) thanks pat x
The flat side of the needle should be towards the shaft and the slot in the needle should correspond to the side the thread comes down.
Feb 22, 2011 | Baby Lock Imagine
I have a Babylock Denim Pro II and the entire mechanism that holds the needle just fell off the machine!! What the heck do I do?
Hey there,
This just happened to me last night, too! I figured out that it tightens back onto the shaft with an allen wrench. I found a tiny allen wrench in my tool box and it did the trick. Hope this helps!
Jan 09, 2011 | Brother LS-1217 Mechanical Sewing Machine
My babylock says THE SAFETY DEVICE HAS BEEN ACTIVATED. The belt is not broke. I have changed the needle and pressure foot and still when you start to sew it does nothing and the above wording comes...
When you get that error message it usally means there is a jam in the machine that is causing the motor to work to hard so it keeps you from burning up the motor try taking your needle plate off and bobbin case out and then put your needle plate back on and then the bobbin case if that doesnt work try looking at the take-up lever there might be thread wraped around it soaking up the oil and causing a bind
Jul 02, 2009 | Sewing Machines
How to get the safety device actived error to go away and sew again???
The reason you are getting this messege is because something is in a bind, could be a shaft or even on of the step motors. You will need to get in into your local Babylock Dealer and they will be able to find the bind fairly easily.
I personally have 25 years working on Babylocks and am familiar with this problem
Jun 30, 2009 | Baby Lock Ellure
Mar 19, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Baby lock denim pro
try putting some bee's wax around your spool
Dec 09, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
90 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
