Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Getting error 316 when trying to uninstall skyplayer
  • 38 Answers
This could be that your progam files are coruppted. First try to install that program without unninstalling the old one. This should fix the coruppted files. And only then uninstall it. Good Luck.
Posted on Oct 04, 2009
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
093 316 error code
093-316 RAP Cyan Dispense failure
How to easily fix (error 316)?There are two (2) ways to fix 316 Error:
Advanced Computer User Solution (manual restore):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Error 316) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Aug 22, 2013 | Xerox DocuColor 240 All-In-One Laser...
Uninstalling a java from programmes and features.error 316 appeared. any advice
try to uninstall java from this program
http://revo-uninstaller.en.softonic.com/
Its free and works better if javas own uninstall function is broken
May 04, 2011 | Computers & Internet
My web cam will not take photos or show video
I would try to download the updated software from the manufacture website. Make sure to uninstall the old drivers first.
Oct 06, 2010 | Genius Look 316 Webcam
Error code p-12 316
Error P12-316 means:
Type: P12 - Master-disposal-section motor lock. Point: 316 - Master-compression-motor encoder sensor count did not change within 10 milliseconds after the master compression motor activated.
Hints: Check mentioned sensor. Check mentioned motor.
Aug 24, 2010 | Riso RZ390 Duplicator
Drver for genius 316 webcam
Try here
http://www.nodevice.com/driver/company/Genius/PC_Camera.html
Jun 03, 2010 | Genius Look 316 Webcam
I just paid for the skyplayer on the internet, now the xbox will not let me sign in to my profile, wat is wrong??
As all of the people are trying to get log in to sky but there is a big problem that there is a massive demand of the service and servers are crashing right now. The Xbox is now resolving this problem but it will take a few days. Soon you will be able to log in to your sky account. There is also an article about fixing this problem on bbc news website
Apr 29, 2010 | Microsoft Xbox Console
I don't know how to get my sky player setup on my xbox
http://www.xbox.com/en-GB/skyplayer/
you have to go on this web site and sign up. you also need to be a gold member to get access.
Oct 30, 2009 | Microsoft Xbox Console
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
64 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
