Question about Sharp AL 1631 Copier
Al1631 sharp copier
Letter and number alternately appear and unit will not work
  • wallan May 11, 2010
    The letter and number indicates a failure code.
  • Sharp Expert
  • 255 Answers
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
Posted on Oct 05, 2009
H and 4 appears alternately on SHARP AL-1226
Press the key simuteniously C ,Density Key& C Then press 14 and press start key, then machine auto restart. ok
Dec 17, 2013 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
Indication problem
Fuser unit abnormality check it?
Dec 17, 2013 | Sharp AL-1217 Copier
A letter and number appear alternately
What Letter and What number?. These usually come up as L - 1 or H - 4...both of which are easily resolved. Just let us know what code is flashing.
Feb 03, 2011 | Sharp AL 1631 Copier
Does the sharp al1631 have a hard drive
There is NO hard drive in the AL1631. I have worked on hundreds of these and can say with certainty there is no hard drive.
Thank You for using Fixya.
Oct 20, 2010 | Sharp AL 1631 Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
Sharp Al1631 unit won't copy; just spits out blank papers
check for empty toner... and if the laser lamp is dim or out... the laser lamp is the lamp that comes on when you copy from the glass table or through the document feeder
Dec 09, 2009 | Sharp AL 1631 Copier
ROLLER ROTATING KNOB TURNS CONSTANTLY ON SHARP AL1631
Many copiers will do this if you have run out of toner.Copiers will turn over trying to add toner from the cartridge to the developer unit.
Nov 18, 2009 | Sharp AL 1631 Copier
SHARP AL1631
Check the scanner lock knob.
Apr 21, 2009 | Sharp AL 1631 Copier
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
Sharp AL 1631 Copier Logo
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
