Question about Nikon Coolpix 2500 Digital Camera
When i turn my camera on,there is a red flashing icon to the right on top???
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
I have a nikon camera and there is a small red hand flashing at the top right hand corner,How can i get this to go away?
Hello
OK, the red hand icon that's flashing indicates that the camera is using a slow shutter speed, and is warning me to be careful to hold it steady.)
So, basically you will just need to increase the shutter speed, and the hand will go away. This setting is usually done in manual mode.
Kind regards
Andrea
Aug 20, 2010 | Cameras
How do you turn the flash off so I can take pictures where a flash cannot be used?
Press Right on the cursor button (marked with the lightning bolt icon) to switch the flash setting. Your choices are AUTO, AUTO/Red-eye reduction, Forced ON, Forced ON/Red-eye reduction, Slow sync/Red-eye reduction, and Forced OFF.
Apr 19, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
How do i turn off the flash on the cannon power shot a530
Press the Flash button (the top part of the circular "joystick" button, marked with a lightning bolt) to cycle through the options. You can choose from Auto with red-eye reduction, Auto, Flash on with red-eye reduction, Flash on, and Flash off. You want the lightning bolt in a circle with a slash through it.
Mar 29, 2010 | Canon PowerShot A530 Digital Camera
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
How to set picture resolution.
Turn the camera on and set the slide on the right hand side to the red camera icon, as if you are taking photos. Turn the dial on top of the camera to the red camera icon. Press the middle circle button (menu/set), you will see that the 'picture size' menu is highlighted. Press the right arrow key to view the different resolutions available, select with the up, down and menu/set button. Press the menu/set button again to leave menu. To change resolution in intelligent auto mode, do the same thing but turn the dial to the red camera with the 'iA' in it.
Sep 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Lg viewty camera flash not working
This worked for me: I turned the ISO to 800 and set the flash to "auto" - even in quite bright light the flash still goes off so I'd definitely try this. To turn the image stabiliszer off, press the "unlock" button next to the shutter on the side of the phone.
Dec 02, 2008 | LG KU990 Viewty
Flashing icon
Low shutter speed icon means that when you take photo the image will be blurry if camera moved.
Is there this icon when flashlight is turned on?
Feb 13, 2008 | Nikon COOLPIX S6 Digital Camera
Flash icon
Same problem with the red flash icon. I can take a picture if I turn off the flash as well, but have to turn off the flash every time I open the lens. Have had the camera for 5 years and haven't had a problem. We needed to replace the lens cover recently and after we replaced the cover we started having this flash problem. It was working fine before the cover came off which leads me to believe we've changed our settings somehow....pleas
Dec 26, 2007 | Olympus Camedia Stylus 300 Digital Camera
Flash doesn't work
a daft question I know but you have pressed the flash button (right hand side of the group of three on top) to change flash mode and is it clicking like the other two?
Dec 18, 2007 | Kodak EasyShare DX6490 Digital Camera
Nikon Coolpix 2500 Digital Camera Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
