Question about Samsung LA40A550 40 in. HD-Ready LCD TV
Picture goes off after a few minutes but sound remains. what is the problem?
    Novelist:
    Champion:
  • 210 Answers
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Posted on Oct 02, 2009
Shuttle83
  • 1139 Answers
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 16, 2008
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
maatmartin7
  • 1213 Answers
SOURCE: 47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Posted on Nov 23, 2009
roety
  • 585 Answers
SOURCE: The picture on my TV goes black after few seconds
Hi my name is Roety,
I can help you with your issue ,
Sounds like a lamp going bad
No model listed makes it hard to guess here
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Dec 15, 2009
  • 8457 Answers
SOURCE: polaroid tv screen goes black after 30 40 minutes,
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Posted on Jul 05, 2010
New power supply board and screen goes black
It sounds that the off timer has been set to one hour. Check it.
May 29, 2013 | Philips 47PFL3704D 47 in. LCD TV
I have a Samsung LNT4071F. When I turn my tv on it will start to flicker and then the video will go but I will still get sound. On some occasions the picture will come back for a few minutes and then start...
Sounds like the inverter needs replacement if the picture goes out but audio still works. Thats the classic sign of a failed inverter board. You can get the replacement inverter board from www.tvrepairworld.com
Oct 18, 2012 | Televison & Video
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Jul 05, 2010 | Polaroid FLM-3232 Television
My magnavox 42mf438b lcd tv will be fine for about 10 minutes when i turn it on, then the screen goes completely black but it still has sound. it stays like this even if i turn it off and back on. i can...
that set is highly rated by users .. it first came out in early 2009 (i think) so you might check to see if any warranty remains ... the display is illuminated by several lamps .. each lamp has its own high voltage inverter .. all the innverters are powered by an output of the low voltage power supply (often 18 volts)... i would suspect a problem with that low voltage power supply.. either a bad capacitor or a thermal issue .. .. ..
Apr 10, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Lg 42 picture turns off after a few minutes
that problem in most cases is caused by your mainboard failing Check shopjimmy.com or Andrews Electronics for price and avail.
Dec 02, 2009 | Televison & Video
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
After a few minutes of the t.v being on the picture will suddenly go of as if the T.v. puts itself into standbye mode, once this happens the only way to get the picture back is but switching the T.V. off...
Sure wish we knew which brand and model of set it is, but it sounds like the tv is going into shutdown possibly caused by bad solder connections or a weak component on the circuit board. The only thing you can do yourself on this one is to disconnect the power cord from the wall for a few minutes and hope it clears out any confusion in the microprocessor. Otherwise, you need a service person to go in and check it with test equip. Good luck, Russmann.
Nov 12, 2008 | Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Screen goes out but sound remains
A blown fuse would not be intermittant.
It is possible that the back plane lamps, and or the back plane power supply is failing.
When the set is in the dark screen, shine a flashlight on the screen at an offset angle. Look carefully and see if you see the picture images. If so, this proves that the back plane lighting is having a fault condition. If there is no image at all, then there may be a fault condition with one of the drive boards for the picture processing or the screen itself.
Jerry G.
May 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Samsung LA40A550 40 in. HD-Ready LCD TV Logo
196 people viewed this question
Henry  Thomas
Henry Thomas
