Question about Microsoft Windows XP Professional for PC
Stack buffer problem cant reboot even in safe mode with command prompt. I keep getting blue screen even after entering %systemroot%\system32\restore\rstui.exe.
It could be the physical memory problem. Do a memory check.
Posted on Oct 02, 2009
I forgot my laptop password
You can try the following:
If your S.O. is Windows you can try any Windows Password Recovery Tool
Alternatively you can ty( if Windows):
Step 1: Boot or Reboot your Windows laptop (it is a Windows 7 example ).
Step 2: Hold on F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Or Press CTRL to enter Advanced Boot Options when computer power on.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and press Enter.
There are three options for choice, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. In order to reset Windows user password with command prompt, select Safe Mode with Command Prompt.
Step 4: Wait for Windows 7 to load files until Windows login screen comes out.
Step 5: Log in with an administrator account or built-in administrator when you see login screen.
Step 6: Command Prompt runs automatically. Type net user in the Command Prompt and press Enter to see how many user accounts in locked laptop. Then all of laptop users will be listed in the Command Prompt.
Step 7: Choose one administrator to reset forgotten password for laptop.
Type net user fuzi 123 and hit Enter. Suppose 'fuzi' is your locked Windows user name. Then '123' would be new password you reset for it.
Step 8: Login your laptop with the new password after successfully laptop password reset.
Sep 30, 2016 | Computers & Internet
Nls error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 21, 2013 | Acer Aspire One PC Notebook
Bios password
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps.
Jan 10, 2013 | NEC Versa Computers & Internet
Bios locked on start screen. admin password needed
Enable VGA mode
Reboot
DEBUG
o 70 2e
o 71 ff
Quit
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
G <ENTER>
Q <ENTER>
Dec 29, 2012 | ASUS X401a 14.1-Inch Laptop Black Intel...
Remove virus of my computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials
Dec 13, 2012 | Computers & Internet
No login screen windows xp pro cannot login
You need to restore your PC in safe mode:
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
Use a sytem utility software like RegInOut to avoid such kind of errors in future. It will also fix corrupt registry and windows files.
Dec 27, 2011 | Computers & Internet
I have a HP a0310n desktop. I is rebooting in a
Well you can try in safe mode with command prompt and than
To start System Restore using the Command prompt, follow these steps:
See if that works
Jul 31, 2009 | HP Pavilion a1310n PC Desktop
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Dell Optilex GX300 checkpoint [Vmgr]
Items in blue which are underlined are clickable to give more information about the process
Start the System Restore Utility at a command prompt
1. Restart your computer, and keep tapping F8 during the initial start-up until you get options, select Safe Mode with a Command Prompt then press enter.
2. Log on to your computer with an administrator account or with an account that has administrator credentials.
3. Type the following command at a command prompt, and then press ENTER:
4. Follow the instructions that appear on the screen to restore your computer to an earlier state.
Look for the most recent system checkpoint created before the errors to restore from
For additional information about the Safe mode with a command prompt, click the following article number to see a description of the Safe Mode Boot Options in Windows XPthe article in the Microsoft Knowledge Base: 315222
Mar 06, 2008 | Dell Optilex GX300 (188TD) Motherboard
Microsoft Windows XP Professional for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
