Question about HP PSC 1315 All-In-One InkJet Printer
I have a PSC 1317 Need to print on card .015mm but it just jambs
5 Suggested Answers
  • 199 Answers
SOURCE: Printing problems with HP PSC 1317
remove the cartridge from the printer . in the bottom of the cartridge you can see the ink nozzles.shake the cartridge well & you can see the ink is coming out from the nozzles.clean it with tissue paper and put it back. or dip the cartrige in the warm water (be careful not dip the enter cartrige. only the bottom nozzles part )for one minute and shake the cartrige well.clean the nozzle with tissue and put it back.
Posted on Sep 25, 2009
  • 4350 Answers
SOURCE: need hp psc 1317 series installation windows disc
you can get what you need, for free from HP.com. Printers often should NOT be installed via Plug and Play, especially HP.
Follow the install directions exactly.
Posted on Nov 06, 2010
  • 6771 Answers
SOURCE: need to install a hp psc 1317 all in one without
Go to www.hp.com for driver downloads.
Posted on Jan 05, 2011
prashant2012
  • 1127 Answers
SOURCE: Have put new ink into
hi
check your have fix your printer cartridge properly and check you buy the original,
Posted on May 31, 2011
Printer wont print
Just a suggestion, if you had another printer connected before this one - or the default printer is still set as default - when you click, ' Print' you'll need to select your HP 1315 as the printer you want to use to print your document.
If that's not the problem and you need further assistance, click here:
http://bit.ly/dsX0dX
Jan 10, 2010 | HP PSC 1315 All-In-One InkJet Printer
Old hp psc 1317 printer unable to install
To connect your PSC 1317 printer you need to install the software onto your computer and as you did not provide me with the operating system I will provide you a weblink from were you need to navigate to the exact operating system and follow the onscreen instructions.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=374584&lc=en&cc=us&dlc=en&lang=en&cc=us
I am sure this will help..
Yours Always,
Mujahid498
Sep 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Sep 25, 2009 | HP PSC 1315 All-In-One InkJet Printer
How to instal my hp psc 1317 without a cd
go to http://www.hp.com/#Support enter your product name/number (psc 1317) then your operating system and it will give you available downloads for drivers and software
Sep 16, 2009 | Computers & Internet
Check print cartridge light flashing
Hi !!
It means that you need to refill your cartrige or replace it with new one. Hopefully it will solve your problem. If you still have any query let me know please.
Thanks Irfan view
May 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1317 All-In-One InkJet... Problem:
You can download this software/drivers on the HP website under the support section. All you will need is your printer model # & the operating system you are using. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Office Equipment & Supplies
My all in one hp psc 1317 has gone off line and nothing i do seems to get it back on
First check the printer icon. ( Make sure the printer is turned on during this process)
Go to Start Control Panel Go to Hardware and sounds Go to printers.
And check that the printer PSC 1317 has a check mark.
If not right click on the same and left click on Set printer as default.
Next make sure the printer icon says 0Ready.
If not right click on top of the PSC 1317 icon and left click on Clear all documents (untill it says 0ready)
If it still does not say 0Ready.
Then Go to Start Then Run(if not where you see start search Type there as Run and hit enter in the run Box type services.msc and click Ok
Now in the services window Scroll down an locate for Print Spooler and double click on the same
Now under Services status If Start is highlighted Cliick on start ( now a small window will poppup and close)
If Stop is highlighted then click on stop ( A small window will popup and close, Now you will see start highlighted Click on start and then either click on apply or ok close all the windows and restart your computer.
Now First
Go to Start Control Panel Go to Hardware and sounds Go to printers.And check that the printer C3180 has a check mark and if it says 0Ready.
If yes Right click on the same icon and left click on Properties.
Now in this window towards the bottom right you will see a tab which says print test pageClick on it to see if it prints a test page.
If yes then Try to print a document.
If non of this works
Go to Start Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware)
And deleted any or all the icon which says PSC 1317
If it is not deleting then right click on the same icon and lecft click on cancel all documents Then unplug the USB cable which is connected to the printer end and leave it unplugged for atleast 1Mins before reconnecting (In the meantime reboot your computer)
After rebooting the computer connect the USB cord to the Computer it should install the printer diriver on its own (if it prompts the CD then insert the Cd if you have it handy) it may take some time to install the prnter driver
Then
then PSC 1317 See.if it says 0ReadyRight click on the same icon and left click on Properties
Now in this window towards the bottom right you will see a tab which says print test pageClick on it to see if it prints a test page then try printing any document or Email.
Let me know if any problem
Good Luck
Nov 04, 2008 | HP Office Equipment & Supplies
plz visit the manufacture website and download the drivers for free
Jun 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
