Question about Apple iMac 24" Desktop
Optical drive stopped working Wont recognise the drive anywhere Already repaired permissions Eject wont work from any application or from the keyboard. Has a disc stuck in it and does not spin at start up.
  • 33 Answers
You will need to replace your optical drive.
Posted on Oct 02, 2009
Cd not recognised even though device manager says drive is working well Help please?
It seems that you have no problem with software side. Then obviously the problem is in the hardware side of your DVD drive and need technician service.
Thanks
Sep 22, 2014 | Computers & Internet
Screen is grey and keyboard wont respond.
Five ways to eject a stuck CD or DVD from the optical drive
Ejecting the stuck disc can usually be done in one of the following ways:
1. Restart the computer and after the chime press and hold down the left mouse button until the disc ejects.
2. Press the Eject button on your keyboard.
3. Click on the Eject button in the menubar.
4. Press COMMAND-E.
5. If none of the above work try this: Open the Terminal application in your Utilities folder. At the prompt enter or paste the following:
/usr/bin/drutil eject
If this fails then try this:
Boot the computer into Single-user Mode. At the prompt enter the same command as used above. To restart the computer enter "reboot" at the prompt without quotes.
Jan 25, 2013 | Apple Computers & Internet
My toshiba laptop does not recognise any DVD which I inserted (the laptop is able to detect the DVD drive and the LED on the drive blinks when I inserted the DVD. In addition, I am unable to eject the DVD...
Hi There and Welcome to FixYa!
It seems like you're having some serious optical drive issues there. Based on how you described the problem, I would think at the onset that there is somewhat of a 'conflict' in your OS' registry (if you're using Windows, that is). I recommend that you go and visit the site below from Microsoft :
MS Drive Issues
Clicking "Run Now" will download the executable file. After completing the download, go ahead and run the application (making sure that all other applications are closed). What it does is it will clear any conflicts from the OS registry. After the procedure, restart your computer.
If this does not resolve this problem, then I would strongly suggest that you replace the optical drive in order to completely fix this issue.
I hope this helps, and Thank you for using FixYa.
Feb 26, 2011 | Toshiba Computers & Internet
I have macpro 13inc.my problem is my disc is not working with the eject is not function.so still my dish is inside of my disc unit how can i remove manually pls. give me instruction properly thanks lot...
Thanks for contacting Fixya Support.
With the Macbook Pro 13" having a Superdrive or Combo optical drive, you are dealing with a slot-loaded drive. As a result, if you have a disc that is loaded into your optical drive, which will not eject, then there isn't a manual way to remove the disc without causing damage to either the optical drive or the disc itself.
In most cases, of a potentially stuck disc in a Apple notebook's optical drive, a visit to your local Apple Retail Store Genius Bar or local Apple-authorized service center would be highly recommended.
With that noted however, here are some troubleshooting steps to try from the Mac OS X side first before having to take that step and visit an Apple service provider:
- CD DVD EJECT -
- - Reboot your Macbook Pro 13"
- - Hold down your Media Eject key on your keyboard pad prior to the Apple Chime starting.
- - Keep holding the Media Eject key down while your Macbook Pro 13" boots up
- - The disc should eject before you reach your Desktop
- - When it does, simply release your Media Eject key.
If that does not work, try this:
-EJECTING DISC USING TERMINAL-
From your Desktop:
* Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
* From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities folder.
* Locate and open the Terminal application.
* At prompt, type: drutil eject and press the Return key on your keyboard
This command line should eject the disc from the drive, unless there are mechanical issues with the drive.
If neither of these steps work, then I would be remiss as an Apple Certified Tech, if I did not recommend you proceed to take your Macbook Pro 13" in for service.
I hope this helps.
Best Regards,
-Mactechtrainer
Aug 26, 2010 | Apple MacBook Pro Notebook
CD wont eject from drive
Have you already tried to mannually open the tray, by inserting a thin straight object (like a unbent paper clip) in the manual eject hole on the optical disk drive? The hole exists for that pupose.
Jul 18, 2009 | Dell Studio 15 Laptop
Mac desktop image wont change
on the main drive there is a folder called "Library" in that folder should be another folder called "Desktop Pictures" I suggest checking that folder to make sure the images are present. Also try checking permissions using "Disk Utility" located in "Applications" --->"Utilities Folder" select the main disk in the list on the left and select repair permissions. As a last ditch effort you can reinstall the base system and then restore to time machine as time machine will not restore system components
Apr 19, 2009 | Apple Computers & Internet
Maxoptix t5-2600 Will not eject MO Disk
As far as I know the green led means "write" & red led means "read". Don't increase time out on the SCSI card . If you press eject button wait 10 secs. If no response I think your MO drive having some problem . Or your jumper setting doesn't right.
I using t5-2600 on SunOS so I'm not exactly know what's problem on your drive. But Maxoptix MO drive very durable. I bought from ebay and manufacture date were 1999 . Oh my god . Just almost 10 years . And working good.
Apr 14, 2009 | MaxOptic Maxoptix Star T5-2600 Internal...
TomTom go 700 flashing cross at start up
U need just one original file from zour tomtom and that is ttgo.bif so keep that file safe and copy everything from working unit (even better with patched system) to your unit, !!!!! dont use TomTom Home !!!! just through drive (if its not there cant help), just possible that u need now maps activated for your unit, u can find info how to this anywhere,
Jan 25, 2009 | Tomtom GO 700 GPS Receiver
Problem opening quarkxpress on g4 mac
The first place to look is your permissions. Open your utilities folder in your applications folder and launch **** utility. Click on your hard drive icon and click the repair disk permissions button. It may take a few moments to run. That might solve your problem.
If that does not solve the problem. Open library/preferences/Quark. Move the pref' doc in that folder onto you desktop (don't trash yet) try relaunching the app. If still not working trash the pref' and try again.
If all that fails I'm afraid you'll have to re-install the app'
Sep 28, 2008 | Apple iMac G4 Desktop
Wii wont take disc in
The drive sensor or the motor for pulling in the disk isn't working. Also, make sure there isn't a disk already in the wii by hitting the eject button. You'll need to send it in for repair if there is no game in it.
Aug 10, 2008 | Nintendo Wii Console
Apple iMac 24" Desktop Logo
122 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
