How do i remove the top to my whirlpool washer lsr8233jqo
  • 5,911 Answers
To remove the exterior casing of the washer to access the interior, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the consolehow do i remove the top to my whirlpool washer - 2.gif has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console2.gif will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
Posted on Oct 02, 2009
Washer will not drain or spin
sounds like the timer has failed...try manually selecting spin mode...that should give a indication.
Jul 21, 2010 | Whirlpool Washing Machines
I need to remove the top of whirlpool washer lsr8233jqo and can't figure out how to get it off to replace lid switch
Behind the control panel is a screw on each end you remove with a long slender phillips head screwdriver. You can then flip the control panel up and get to the innards. Pop the S-clips, remove the lid switch quick connect and tip the case forward. You can now replace that lid switch.
I have a couple of vids I spyed on line. One is lidswitch replacement and the other shows how to get into numerous styles of these sweet machines and I have a 3rd one on how to replace the pump and more here
May 30, 2010 | Whirlpool Washing Machines
Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My model # is LSR8233JQO.SIR. CK4409148.TYPE111.I'm tring to find a water value.Model cannot be fond.
CLICK HERE
The model number ends in a zero, not an O
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Top Load Washer LSR8233JQO no spin & no drain
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949247) and the lid strike will be listed as item number 20 (part #358684). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool lsr8233jqo - will not spin
if you hear the motor running then it is most likely the direct drive coupling between the motor and transmission. part #285753 you can see it from under the machine.477922b.jpg f3941f5.jpg
Jul 16, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool LSR8233JQO
The pump is coupled to a motor that runs it. The pump is ok if it is not leaking. You need to check the signal to the motor to turn on. It all comes from the timer switch unit. The coupling probably should be relpaced if the pump is really bad. Sounds like the drive motor for the tub, not the pump, or the switch unit.
Mar 24, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool LSR8233JQO Washing Machine
My idea is to oil mine and I came on here to find info on how to remove the back, it's impossible!
Sep 23, 2007 | Washing Machines
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
