Question about Garden
Replacing fuel lines and filter in gas tank. How do I install new filter intank and connect to new fuel line when I can't reach inside the tank to hold the filter and plug in place while I press the new fuel line on.
  • 73 Answers
Usually you can remove the tank and the hoses run thru a rubber gromet. pull that gromet and the hole is big enough for the filter to come out. makes it easy access. This all depends on the type or tool you have.
Posted on Oct 02, 2009
I put new fuel pump on, it work fine when in a coffee can of gas but will not when in tank. WTF
Power not reaching pump while in tank. Check for bad fuse or relay in power line to pump.
Sep 18, 2015 | Cars & Trucks
How does a weadeater edger pe550 gas lines hook up inside of the gas tank?
I am not familiar with your brand of machine, BUT... many machines have similar fuel line setups. Here\'s what I know.
Most carburetors have built-in fuel pumps that suck fuel from the tank. As the fuel pumps generally suck more fuel than the engine needs, there is a "fuel RETURN line" from the carb back to the fuel tank, which returns the excess fuel back to the tank. There is usually nothing attached to the end of this line inside the tank.
The "other" fuel line is from the tank TO the carb, and it usually has a tiny, weighted, fuel filter attached to a long piece of fuel line INSIDE the tank. This long, flexible, floppy piece of tubing allows fuel pickup regardless of how, what position, the machine is held.
The purpose for this set-up is threefold:
  1. The filter, of course, is to keep "trash" out of the fuel system and,
  2. The "long" fuel line inside the tank is to allow the filter/pick-up end of the fuel line to move around in order to pick up fuel from ALL points inside the tank,and
  3. The weight is to forcefully "carry" the filter/pick-up intake to the low point ["bottom"] of the tank regardless of the orientation of the machine and fuel tank!!!
On the machines that I replaced the fuel lines, to replace the suction line I had to use a longer than normal [when finished] length of line.
I first had to "fish" the filter, weight, and any nipples and or washers out of the tank.
  1. I then inserted the new line into the tank from outside through the small hose opening hole.
  2. To start, I put MUCH MORE [extra] line into the tank so that I could fish-out 5 or 6 inches thru the filler opening, allowing me to finish the connection of the filter, weight, nipple(s) and/or washers outside the tank where I had room to work!!!!!
  3. The use of nipples with washers expands the hose enough to keep the assembly from easily falling or pulling from the tank.
  4. Once all of the "in-tank" assembly was done, I then gently pulled the extra fuel line back out of the tank hole, thus pulling the weighted filter and connectors back into the tank. I left enough "loose" tubing inside the tank to allow the weighted fuel pick-up end to reach anywhere inside the tank.
  5. The final step was to route the line to the suction nipple on the carb, cut the line to proper length, and attach it over the carb suction/intake nipple.
Not being familiar with your machine, I can only hope this allows you to fix your machine! Good luck!!!!!
Jul 23, 2014 | Poulan WeedEater Hedge Trimmer 25cc Engine
How to change my gas line on a 17 inch 25cc gas weedwacker trimmer/edger
basically this is a very simple thing to do as long as you have purchased the correct size of hose. Before removing the fuel line from the tank remove it from the carburetor. then you need a small bent wire or something like it to fish the filter out of the fuel tank. When you have that done you need to remove the filter and just pull the fuel line out. When you install the new line in the tank you need to snip the new fuel hose at an angle to help in the ease of re installing it. Once you get it started you can either reach into the tank with needle nose pliers and pinch it so you can pull it back into the tank. Or you can just twist it in a circular motion until it feeds itself into the tank. The rest is common sense. Install the fuel line filter and put it back into the tank then suck a little gas up the line so the carburetor don't have to do it. that'll prime the line and make it easier for the trimmer to start.
Jun 29, 2014 | Craftsman 25cc Gas Line Trimmer
How to change fuel line on craftsman blower
Before you start take a picture of where the old lines are connected to the carb and the primer bulb for future reference.
To replace the line pull the spark plug wire from the plug. Remove the old line from the tank and remove the fuel filter from the line. Take new larger line and cut it on a 45 degree angle/or trim as necessary so you can grip it from inside the tank and pull it into the tank. Perform the same operation on the smaller line as well. Be sure to leave enough line for the fuel filter to reach the bottom of the tank. Install the fuel filter. The other small line is a vent line and only needs to come inside the tank not go to the bottom in the fuel.
Good luck.
Jun 07, 2014 | Craftsman 4 Cycle Blower/Vac
Craftsman Gas Powered Blower Mode 358.794772: Fuel lines broken and need replacement. Have new parts from Sears. One fuel line goes to the carb and connects to the fuel filter inside the fuel tank The...
A special fuel filter must be on the end of the fuel lines going into the tank, the line should be long enough for the filter to move around by gravity to stay in the fuel as the tank empties.
Sep 13, 2013 | managemylife.com
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
Craftsman Brush Wacker routing of fuel lines Model 358-795200 Was laying in bottom of top mount gas tank
Use new fuel line. There should be two things (besides fuel line) in the fuel tank. The small line has a (1) fuel filter attached and is routed to the lower outlet on the carb. This is the fuel supply line. Make sure there are a few inches of it inside the tank. (say enough to reach other side of tank). The larger line should have a (2) nylon connector inside the tank holding it. The connector stays right at the tank hole. That larger line goes to the closest outlet on the purge bulb. The other fitting on the purge bulb should have a larger line that connects to the upper fitting on the carb.
Feed enough length of fuel line thru tank holes to pull them out where cap is to put on the filter and nylon connector...then pull them back thru. WD-40 will aid in this procedure or any light oil.
Jun 10, 2010 | Craftsman Garden
The Craftsman Sim-Pul string trimmer starts and runs for one sec.
The larger line is the fuel return line from the purge bulb and should have the nylon connector (funnel thing) on it holding it in place inside the tank so the line won't pull out.The smaller diameter fuel tank line goes from the tank to the lower pipe fitting on the carburetor (fuel intake line). This line has a weighted fuel filter inside the tank on it.
New fuel lines are recommended every so often as the ethanol added to our gas nowadays wreaks havoc on the lines and carburetor as well. Get new lines...cut them long....feed them thru holes in fuel tank...grab with tweezers or needle-nose pliars....put on either the fuel filter or the nylon retaining nipple and pull the one with nipple down to bottom of tank...one with fuel filter can stay long to help draw fuel in the tank (yes, it moves around and is supposed to).
Jun 06, 2010 | Craftsman Convertible 25cc. Gas Line...
Replace fuel line
You can cut the line, push the fuel filter and fuel line attached to it out where you fill it with gas. When you are ready to put new line in, cut the fuel line at an angle so you can push it in the hole. Keep pushing in until it comes out the fuel tank fill hole. Attach your new fuel filter to the line and pull it back until the fuel filter lays in the bottom of the tank. Then cut the line to length and put it on the carburetor. Take the other piece hook on the carburetor and put it back in the tank.
Sep 28, 2009 | Echo Garden
How do I replace the fuel filter and the two fuel hoses on my Homelite leaf blower? The fuel filter is inside the fuel tank.
Take your Model number of your machine and the model, type, and code of your motor to your local small engine repair shop and have them get you your replacement filter and also pick up new gas line. When you replace your fuel lines do one at a time. All you have to do is pull a fuel line off, cut new line to length and re install. As to the filter in the tank, I usually take a coat hanger and fish it up to the top and then use needle nose pliers to grip it. Then just pull off the old filter and install new one.
good luck
Aug 31, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
