I have a WD external hard drive that I was able to load several pictures onto (and stupidly deleted them off of my computer once they were loaded.) Now, whenever I plug the hard drive into a computer (I've tried it on 3), the computer recognizes that I've plugged something in, but I can't access it. In my device manager, it is listed as a disk drive, but how do I get into it from there? This is very frustrating!
  • wriz23 Oct 06, 2009
    the only way i can even view that the hard drive is attached is if i go to device manager. i doesn't show up under my computer.
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 02, 2009
  • Project NOMAD
    Project NOMAD Oct 06, 2009
    You may want to take the drive out of its enclosure and connect it directly to a suitable computer.
    This would tell you right away if it was the drive or the enclosure.
  • 58 Answers
Go to my computer, right click the drive, go to properties, tools and run error checking on the drive.
If the computer is writing cache files on the drive and you unplug it without ejecting it first it goes retarded.
  • 3 Answers
Look up on the main WD site the model number of your drive and make sure you have the correct drivers installed. external drives need drivers too. also make sure your plug and play is accepting external drives.
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
Proper or Best way to use my newly installed WD SATA external Hard Drive;
The files are placed on the drive by you. Unless someone setup a special application files will not automatically migrate to another drive. You would not generally want them to because they would never be where you left them and be much harder to find. Primarily you will want to be moving data files and not application files (unless you uninstall from the internal drive and reinstall to the external drive) You can open my computer and find both drives -- you can drag/drop folders (containing only data, mp3s, videos, etc) between drives. I always like to check these moves by doing a right mouse click selecting properties on each folder separately to assure that an equal number of folders and files were copied before deleting them off of the smaller drive.
I emphasize again moving programs in this fashion will cause them to break. If you have large and seldom used applications you can uninstall them then using the installation process and media provided by the manufacturer then reinstall them choosing the external drive as the destination..
I hope this helps.
Dec 09, 2007 | Western Digital Caviar SE WD800JD SATA...
Hard drive clicks several times when turned on,
I have to say from the sounds you describe the Hard Drive is totally destroyed, the noises you can hear are the mechanical parts inside grinding and clanking together. If the information is critical it may be recovered by a specialist data recovery company, but we are talking £100's even £1000's to do the job, so otherwise I would suggest taking case apart and buying a new hard drive for it.
Sorry its not what you want to hear but it sounds very terminal to me.
The reason the PC can detect a device is that it can see the Interface card that sits between the USB port and the Hard Drive.
Mar 03, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I bought a new WD Elements 350gb external hard drive and it came with a Memeo software CD. It says to insert CD before starting backup. I do not appear to be able to use this external hard drive as a plug...
This software is not linked with the drive (with this particular drive you only get a trial version anyway). Just remove the software from your PC.
Start > Control Panel > Add or Remove Programs > Remove Memeo/ WD Anywhere Backup.
Once you have done that, you can delete everything on it (assuming you never manually put something on it apart from the backup). If so, back it up onto your PC, another drive or CD.
Jan 25, 2010 | Western Digital Elements powered by WD 320...
I have an Acer Labtop 4620z When I turn it on it Freezes after The Desk top Loads... HELP.. Won't let me connect .. virus disks freeze as well ???
Before the desktop tries to load, hit the F12 key a few times until the boot choices menu loads on the screen. Choose to load it in "safe mode with networking"
Once the computer starts up, find all your data, music, pictures you want to save, and back them onto a CD, or external hard drive.
Next, shut off the computer, restart it, and hit the delete, or F2 keyseveral times until it loads the "setup" page. Once you are in the setup page, you need to find the choices for what boots first.
Choose to boot from the CDROM drive. Save the settings. Insert the recovery CD into the drive. shut the PC off. Restart the PC, once the recovery CD starts, then follow the on screen prompts to reinstall the operating system etc.
If this does not work then you have hardware failure of some kind, and need to have someone local look at it, and figure it out from there.
Jul 08, 2009 | Computers & Internet
WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Apr 29, 2009 | Western Digital Passport 320GB External...
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Mar 09, 2009 | Western Digital My Book Essential Edition...
Cannot delete files straight from Western digital My passport HD
HOW TO BYPASS THE CRAPPY SOFTWARE
1. Install WD Smartware and update it.
2. Run Virtual CD (VCD) Manager at http://www.wdc.com/wdproducts/updates/?family=wdsmartwareutilities
to remove the virtual CD drive.
3. Use Control Panel add/remove programs to uninstall WD Smartware.
4. Everytime When you plug the hard drive in Windows will come up with the look for drivers window hit 'Cancel'
5. Now use it as an ordinary hard drive!
Dec 08, 2008 | Western Digital Passport WDXML800UE...
Can't load a 13 gig avi file onto wd drive with 90 gigs free
Typically this is because there aren't large enough fragments to load. Run defrag several times and try again. You might also run the cleanup program and remove any temporary files, temporary internet files and anything in your waste basket before you run defrag.
Please let me know how this turns out.
Nov 23, 2008 | Western Digital Passport WDXML800UE...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
