MARK 12, 12 YEARS OLD HAD SLOW START-UP A FEW TIMES THEN NO START AT ALL. My personal piano! I AM OLD TIMER RCA ELECTRONICER AND CAN FIX IT .... BUT REALLY MUST HAVE A DOWNLOAD OF THE SERVICE MANUAL FOR THE POWER END OF IT. IF I FAIL, PLEASE SEND HELP! RICHARD C WEBB webbco@AOL.com
    President:
  • 1,723 Answers
There is no model or any info that I can go on here, how about some numbers form the piano? I can help you troubleshoot the power in if you have a meter and some back ground...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 02, 2009
The pump is slow to start. It cranks for a few seconds before running at full speed. sometimes, after cranking for a few seconds, it shuts off. The unit is 10 years old.
HAVE THE START CAPACITOR CHECKED, SEARCH YOUR AREA FOR FREE POOL PUMP MOTOR TESTING, OR BUY A NEW CAP IT SHOULD BE A 161 @ 110 VOLTS.. OR.. THE START SWITCH MAY NEED TO BE SET OR IS WORN AND NEED TO BE REPLACED. LOOK ON EBAY FOR A START SWITCH. YOU MIGHT BE ABLE TO TIGHTEN THE 1/4 SCREW 1 TURN THAT HOLDS THE START SWITCH, THIS JUST MIGHT SOLVE THE PROBLEM
May 28, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
E belling up right piano serial number 12241 how old is it and aproximate value
Hi.
I did some research for ya, and here's what I've come up with.
The E. Belling piano's were manufactured in the 1920's and 30's.
Their serial number uses 1920 as 01000 for sereal number, so I am assuming that the first two numbers means years in business.
12 years gives us 1932 as the date of manufacture.
The company was one of those that kept getting bought out over and over and over again.
The majority were made under the Patings brand, until 1936, when the company closed.
All were made in the UK, some were for local use, and some for international sales, under the Victor & Belling label.
As far as current value is concerned, I would say that is should be worth at least a few hundred dollars, and possibly much more, depending on condition, and whether any famous songs were ever written on that particular piano.
I hope that I helped you out some, and good luck !!
Mar 12, 2011 | Computers & Internet
How long to cook in a Tower compact slo cooker (old model)
As to the the slow cooker recipes...Try going to www.goodbks.com and search for "Fix-It and Forget-It" cookbook for starters.
As to then 4 or 8 hour timing I'm assuming you don't have an owners manual for it. I would start out treating it as a 4-hour timer and adjusting the times for various dishes aas you learn the cookers "personality"
Hope I helped a little!
Nov 12, 2009 | Crock Pots & Slow Cookers
T2300 @ 1.66 Ghz, 981 MHz, too slow to run
nx6310 (now obsolete ,zero HP support on this) 12 years old.
in dog years that is 84 years.
all that and no OS stated is this DEAD XP" the virus magnet?
if yes, all XP are infected and slow, I'd bet you that !
It came with XP if not XP say how it got changed,using what.?
well , in my opinion all PC are slow. it is a relative term
compared to what? or when? 12 years ago?\
and doing what, that actions you do , seem slow. 100000 possible on all computers. endless apps or the OS it self just slow.
lucky you the CCFL screen back lamps are not dead as most are after even 5 years much less 12. a real shock that is.
Slow 101:
12 year old computers are slow, all are that old , (progress = speed)
12 year old XP is now infected. most are, and zero support from HP nor MS.
The HDD is slow, if not upgraded to SSD all HDD are slow and pathetic, try a new SSD and see the one thing that can make any PC go vastly faster, SSD, spend $100.
the HDD is fragmented run defrag now.
the OS is corrupted, as all are this old. (see virus and malware )
best is to retire it, get PC that is 2007 year or newer.
with w7 or newer.
and win, and have future.
do not invest cash in this junk PC for at least the reason of CCLF
if those die as they surely will , the cost to fix it as huge.
Id have never attempted to up grade any NX PC
none on the HP official retired list
Feb 24, 2018 | HP Compaq nx6310 Notebook
When i turn on the laptop why does it takes so long to load up? and also when i click on my apllications it take 5 minutes or more to load up.....what hould i do?? it celeron
Hello. If your laptop is old it is slow because the solder in the circuit boards slowly fry over a period of a few years. The only fix is a new laptop. I personally but the cheapest one I can now days, under 400. and when it gets painfully slow I replace it.
Aug 02, 2009 | HP Compaq nx6110 PC Laptop
Will only fill and drain
It sounds like the timer/controler is broken replace it. Peter
Mar 18, 2009 | Washing Machines
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 | Amana Ovens
Sony KP-43HT20 Projection TV
5 times blinks is error code for No Good White Balance and you said that picture is very green.
As you know TV is approx 7 years old so it needs RGB gain adjustments.
If you are TV tech person or know about TV repair, let me know to guide you further. Or contact local TV repair shop to fix it.
Oct 26, 2008 | Sony KP-43HT20 43" Rear Projection...
21 people viewed this question
 Grubhead
Grubhead
