Question about Minolta magicolor 330 Laser Printer
How do i get rid of the error message that says "top stack full" when there is no paper in the top stack at all?
  • Minolta Master
  • 6,680 Answers
Sensor for the top stack mite be bad
Posted on Mar 01, 2015
3 Suggested Answers
  • 323 Answers
SOURCE: Paper Jam Error 381
Most of the time the jam will be behind the printer. Open up the back door and see if you see any paper stuck in on the roller. Also remove the printer cartridge by pulling on the piece sticking out. Easily slides back in, so no sweat on that part. Let me know if you have already tried these methods.
If that doesn't work. Unhook the Data cable on the back of the printer, shut the printer off, and unplug the power cable from printer. Wait about 3 minutes and plug everything back in and turn back on the power switch. This should erase the queued errors.
Posted on Apr 19, 2008
  • 240 Answers
SOURCE: Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper left..you can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
Posted on May 24, 2009
Why does my printer say there is no paper in the tray when it is full?
from what u did I would look for a broken paper sensor.
It could also be a ripped paper hanging the sw.
it might also be that somehow the operating tray got changed in the config - if u have multiple trays or manual feed
Mar 03, 2015 | Brother HL-4070CDW Printer
Full stack error
Dear your Xante printer asking to you your printer tray is full of printed papers please clear it,also checked output tray sensors carefully,hope you understand.
thanks.
Feb 26, 2014 | Xante Office Equipment & Supplies
I have an epson printer and when I hit print, the paper slides right thru & says paper jam
  • Carefully remove the jammed photo paper. Gently pull the paper up and out of the paper feeder tray.
  • 2
    Reload the paper into the tray. Stack the paper on a flat surface and then carefully slide the paper stack straight into the paper feeder tray---along and aligned with the right side of the tray. Secure the stack in place by sliding the left "edge guide" against the paper stack.
  • Sponsored Links
  • 3
    Press the "OK" button to resume printing. If you had a "Paper is jammed in the printer..." error message displayed on the control panel LCD, pressing "OK" should also clear the message.
  • 4
    Pull the paper from the printer, if the status message reappears and/or the printer doesn't print, and check the paper for folds, buckling and curled edges or corners. Also check the sheets for sticking. If any of your sheets stick or have damage, remove them from your photo paper stack and replace with new sheets. Reload the paper and press "OK" to try again.
  • Performance Chip
    May 22, 2012 | Epson NX415 All-In-One Printer
    What does the error message "out bin full" means
    This error indicates that the sensor that detects when too much paper is stacked in the output bin to allow more paper to exit. This flag sometimes sticks and a quick check is to make sure that nothing has become jammed where the paper exits the printer. Most common cause is the flag getting jammed because someone has remove the paper the wrong way. I have never seen the actual sensor fail.
    Jul 06, 2011 | HP LaserJet 8000n Printer
    Paper jam on top cover but ther is no paper on top
    check for stuck up key sensor, hook type that detect paper passing, some time that key dislocate.
    Apr 15, 2010 | Office Equipment & Supplies
    I am also getting the "printer jam clear paper path" message
    Check paper sensors in the paper path may one of them the shutter is stack.Ensure that the are free and in position.
    Aug 22, 2009 | HP LaserJet 3015 All-In-One Printer
    hope it helps..
    May 24, 2009 | Epson Stylus CX5400 All-In-One InkJet...
    False empty paper tray message
    Dude,
    If an“Out of Paper” message is shown on your computer and your printer cannot pick up paper, then follow the steps below (in the order) to resolve the problem.
    Step 1:Checking the media and print settings:
    1. Remove power cord when the printer is ON, wait a while and then plug it back.
    2. Turn the printer ON.
    3. Place a Paper, which is not ripped, dusty, wrinkled, or bent.
    4. Place the papers of same size.
    5. Tap the stack of the paper.
    6. Verify the stack of paper between 10 to 25 sheets.
    7. Insert the stack of papers into the printer.
    8. Set the paper settings in the print driver.
      • Open a Document in the application, which has to be printed.
      • Click File > Print > Properties > Paper/ Quality tab.
      • In the Size Drop down menu, Select the Size of Paper.
      • In the Type Drop down menu, select Type of Paper.
      • Click OK.
    9. In the Print Dialog box, click OK to print .
    10. Try printing again.
      Note: If this step resolved your problem and you want to print on another media, change the paper in the unit, repeat steps 2 to 7 above for the new media.
    this will solve your problem
    Dec 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Minolta magicolor 330 Laser Printer Logo
    70 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Adorjani Laszlo
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
