i have WD 250 gb external HDD but when i copy the files to it,it copies for few mins then it gets disconnected and then connected again.pls help me fix this problem.cannot copy huge size files at once..
Comments:
Oct 04, 2009
- still for copying 7.6 gb its taking me 54 mins.....
Ensure you are on a USB 2.0 port ! that is most important
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE. Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason. Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Comments:
Oct 04, 2009
- You may want to copy in smaller blocks.
Quite often very large blocks means that they have to be broken down by the operating system before they can be moved.
This increases the page file sizes and can slow down the computer dramatically.
Also double check that you have INDEXING turned off on that drive as that too can cause problems as it means a file is copied then the process of indexing it has o take place before the next block is moved etc..
I would be tempted to stop the copy process if your files are still intact on the source. make sure you turn of indexing and try again from the beginning with smaller chunks of data.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Western Digital 250GB MyBook
MAC TimeMachine no longer sees WD passport 250GB''The storage location for TimeMachine Backups can't...
(More)
MAC TimeMachine no longer sees WD passport 250GB''The storage location for TimeMachine Backups can't be found.''
i have a western digital 250gig hard drive that i need to reformat and i keep getting a box that...
(More)
i have a western digital 250gig hard drive that i need to reformat and i keep getting a box that pops up saying i cant help.. also i have a western digital 1 tb and it picks and chooses when it wants to show up on the pc we want to recover whats on it and then reformat if ppossible
