Question about Dryers
Whirlpool Gas dryer LGC8858E igniter not working. How to replace?
  • 82 Answers
Need take out front panel botom and screw in igniter. remember plug out electric outlet.
Posted on Oct 02, 2009
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Change igniter on whirlpool gas dryer
Must remove the front of the dryer. It is located in the front lower left hand corner. Check the frame sensor too. It is located next to the iignighter.
Sep 17, 2014 | Whirlpool Clothes Dryer Igniter...
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Whirlpool dryer wont heat>replace igniter > no heat
Bad thermo switch located behind back cover in area of duct work. 1/4"x2" white in color, two wires connected to it. Stops ignition from firing.
Jun 06, 2010 | Whirlpool LGN2000LWH Gas Dryer
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer model#LG5791XM- the burner is working off&on
first check to make sure the venting isn't blocked by lint. second, check the igniter, if it is orange in color you need to replace it, it should glow white.
Nov 14, 2009 | Whirlpool Dryers
No heat, no flame, temperature based high heat
if the dryer doesn't shut off you need a new timer. have you replaced the igniter or glow coil? it needs to glow white not orange in order to ignite the gas.
Oct 11, 2009 | Whirlpool LGR5636PQ Gas Dryer
Gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 12, 2009 | Whirlpool LGR5636L Gas Dryer
The dryer runs by does not ignite.
kindly check all wirings to and from the igniter assembly. does the drum turns?
Feb 08, 2008 | Whirlpool GGW9200L Gas Dryer
Gas dryer with no heat
check the ignition might be a glo-bar element or a maintained high voltage spark module. once there is a pilot a flame rod or a millivolt generator opens the main valve for fire.
Sep 03, 2007 | Whirlpool LGR7646E Dryer
Dryers Logo
149 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
