Question about Kenmore Washing Machines
70 series how to replace belt
  • 71 Answers
The kenmore 70 series do not come with belts they have a coupler behind the motor. Fairly easy to replace you can actually find videos on youtube.com to walk you through how to change it.
Posted on Oct 03, 2009
4 Suggested Answers
  • 272 Answers
SOURCE: I am having trouble replacing my belt on my Kenmore 70 series
i've got them down to 10 minutes, but here goes. remove the bolts going into pump, but do not remove pump . remove the transmission bolt with the spacer and this is where you push the belt through and around pulleys.. this is a little more difficult. you will need to take off the yoke spring and move the transmission pulley around until the spin control magnet catches for spin. it will begin to take pressure off of clutch. you will need a long screwdriver or something like it to apply pressure down on the clutch plate this is to allow to to slip the belt thru the bar the spring came off of and under it.. you can then pull the belts around all pulleys and put everthing back in its place and your done...
Posted on Jul 19, 2009
watugot
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
  • 113 Answers
SOURCE: belt replacement on kenmore 70 series heavy duty plus
No belt on this, its a direct drive with a motor coupler..There is a tutorial for this at www.shop.washermd.com Dave
Posted on Jan 14, 2009
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
Jul 18, 2009 | Kenmore Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
I need to replace the belt on a Kennmore 70 series gas dryer. It is 10+ years old. The tumbler isn't turning.
open the back and ur belt should be in bplane site us a flat head screw driver to remove and replace
Jun 20, 2009 | Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Belt replacement on kenmore 70 series heavy duty plus
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
964 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
