Question about Vacuums
Simplicity freedom model f3300 makes loud noise when running.
  • 65 Answers
Sounds like the fan might be broken in the motor
Posted on Oct 02, 2009
I have a simplicity freedom Model S10E we cleaned out the hose and now it will not self adjust to my carpets. I have one carpet that is higher and its hard to push and I have a rubber smell
The rubber smell is the belt slipping up against the roller since it does not have enough friction to fully turn the roller. Either fix the adjustment for a high carpet or install a tighter belt that can cope with the job.
Sep 06, 2017 | Simplicity Vacuums
How do I Pull apart a Simplicity Synchrony?
The noise is likely the brush roll or the lower motor fan if you only hear it when you turn on the brush roll. Remove the bottom plate to examine the brush roll, there are screws on the bottom of the vacuum that must be removed so that the top nozzle housing cover can be removed. Remove the screws to take the cover off the nozzle housing from the brushroll to the lower motor so you will be able to inspect the fan in the lower motor. You have a high quality precision vacuum that is not easy to repair without proper training. It may save money and provide better results to have it repaired by a qualified Simplicity or Riccar repair shop.
Jan 23, 2017 | Simplicity Vacuums
Simplicity freedom vacuum will not self propell ?
there is a seperate belt.one that turns the brush,one for propell..
Dec 13, 2015 | Simplicity Vacuums
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
May 15, 2014 | Riccar Vacuums
I have a simplicity freedom F3700.2 upright vacuum. It has been working wonderfully until now. I plug it in and it won't start. I have tried removing the bottom and cleaning the roller, the bag isn't...
Sounds like a break in cord or plug somewhere. I am not familiar with the particular vacuum myself. Another thought I have when looking around your vacuum cleaner have you seen a red reset button anywhere at all?
Or by chance does your vacuum cleaner have a plug comes off....... (i.e. like a computer)
a few thoughts
Sep 02, 2013 | Simplicity Vacuums
Im trying to replace a fan on a simplicity freedom f3300 vacum. HOW DOES THE OLD FAN COME OFF? It seems to be pressed on but I dont want to brake anything.
Assuming you have the motor out of the fan housings, check to see if you can move the fan around clockwise/counter-clockwise. If the fan is not moveable, the fan has probably melted to the motor housing. Replacing the motor is recommended as the plastic motor housing under the fan is probably damaged/melted. It could still be fixed but there is a possibility of damaging the housing. If after removing the fan following the directions below be sure to remove/trim any melted plastic away from housing before replacing fan. Not trimming the plastic could result in your new fan melting again to the housing when the machine is turned on. If you have an older model pay careful attention to the carbon brush area, if there are plastic posts holding the carbon brush springs, these are easy to break.
If the fan is movable, remove the nut and washers from fan. Use two large flat head screwdrivers and place them opposite of each other under the bottom lip of the fan between the fan and motor housing. (it might be a little easier if you have an extra pair of hands to hold the motor). With the flat heads in place, push the handles of the flatheads toward the side of the motor where the belt shaft is. If the fan does not pop off rotate the position of the screwdrivers and try again. Pay close attention that the fan washer is installed before replacing your new fan. after installing the new fan, rotate it several times making sure it isn't rubbing anywhere.
If you need any further help feel free to contact me.
Tim
TheVacCenter.com
Mar 02, 2013 | Simplicity Freedom Cord - F3300 -...
Loud noise while running
Vacuums typically make a loud noise when running. Can you describe the noise or why you think it is unusual?
Feb 10, 2011 | Eureka Bravo II Bagged Upright Vacuum
Model #3760-2 Bissell upright vacuum- making very loud noise when running. Cleaned all filters- no difference
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Dec 20, 2010 | Bissell Vacuums
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Hi. I purchased a Simplicity Freedom about 2 years ago. I have had it in for various repairs several times. One persistant problem that the repairman cannot seem to fix is the dirt does not fall down into...
You can let the vacuum run alittle longer so the bag fills up with air, also make sure that the bag in on correctly and you have the right bag for the unit. Let me know if this helps.
Oct 12, 2009 | Simplicity Vacuums
Vacuums Logo
358 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
