Motherboeard wont detect my ide drive
I have an hp desktop, which crashed. i removed the samsung ide drive and tried to install it in a e machine. the e machine also uses an ide drive. but it wont recognize the samsung. eveything is connected properly.
  • 47 Answers
You would probably have to set it through the bios. You can enter the bios by restarting the computer and when you see the name of the mother board or computer come up keep pressing delete until your in a blue,or white menu, from there there is an option where you can set what drive you want to boot from. If your not to familiar with computers or bios setup then you should probably get some one experienced to do it. You can screw up things in there if you don't know what your doing,then you would have to reset your bios by removing a jumper from your motherboard for a few mins,a real pain. id give you step by step instructions but bios vary from motherboard to motherboard.
Posted on Oct 02, 2009
Testimonial: "Thank you... i will try that"
    President:
  • 2,600 Answers
The HP drive has what is called an EISA partition on it, this partition holds HP information incase of a recovery. It has to be deleted in order for you to use this drive on another computer. If you have an EIDE / SATA to usb adapter you can attach this hard drive to another computer to access it. The adapter can be bought ast a computer retailer, ebay etc. for about 20 bucks. When you get the hard drive attached, look in "My Computer" to nake sure it shows up there and write down the drive letter it gave it. Below is the procedure to delete the EISA partition, follow it closely and you'll be fine. Just make sure that when you are in the command prompt, you DO NOT do anything with Drive 0 that is your main drive on the computer and that is not to be messed with.
Here’s the trick to delete and remove the EISA recovery or diagnostic partition in Vista. Before proceeding with the deletion action, make sure that at least a set of Recovery Disc Media has been created. Else, you won’t be able to restore your computer to working and factory default condition when any problem on PC requires reinstallation.
  1. Open a command prompt as administrator.
  2. Run Diskpart application by typing Diskpart in the command prompt.
  3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
  4. Then type in list disk and press Enter key to show all hard disk drive available.
  5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
  1. Type list partition and press Enter key to show all available and created partition in the disk selected.
  2. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
  1. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Testimonial: "I am truly impressed with the speed to which you got back to me. Also the step by step instructions on how to correct my problem. You guys are the best... Thanks, Idolmindca"
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
The computer would not boot with a 2nd IDE drive installed
Try setting the jumper on the IDE hard drive to SL (ie slave).
Mar 17, 2012 | HP (SHP) HP DC7100 CMT SRP US HP...
Brand and model of acer aspier am5641-b5560
If I understood you well, the XP OS installed on WD IDE HDD belongs to another computer, in this case you cannot simply install it on your Acer computer and expect it to boot without problems because the hardware is different. What you can do in this case is a fresh Windows installation.
Feb 20, 2012 | Acer AM5641-B5560A Desktop PC & Monitor...
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
Hard disk is not detecting samsung sp0411n internal hard disk is not detecting
Make sure the power cable and IDE cable is plugged in properly then boot your computer up again. If it does not work, test it on another computer to see if the hard drive works at all.
Sep 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Computer crashed. Computer specialist restored drive. now cannot boot windows. Used restore disk. Did not work. computer boots dos screen then shuts down. boots again then shuts down.
Sounds like a Windows issue. Depending on how valuable it is to you to get your data off the drive, I would suggest buying a new hard drive (they are fairly cheap these days), installing Windows on that. Word of advice: Remove your old drive when doing the Windows install, so as not to accidentally select the hard drive your data is on. Once you have Windows installed, shut down your computer, remove the power cord, and install your old drive on a separate IDE channel or SATA connection. If your PC still tries to boot to the old drive, change the boot order in your PC's BIOS.
Aug 10, 2009 | E-Machines eMachines Desktop PC
Hard drive crash after 1 year
if u have new harddrive then simply first remove crash harddrive from computer .
Then if u have sat harddisk connect it with sat cable .
I fu have ide harddisk tehn connect with ide data cable. simply.
May 04, 2009 | Gateway GT5220 PC Desktop
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
Install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Sep 28, 2008 | HP xw4600 Workstation Linux Installer...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
