Question about Lexmark JetPrinter Z22 Color InkJet
Lexmark Z22 printer heads appear to be clogged. I
Lexmark Z22 printer heads appear to be clogged. I have followed all the troubleshoot advice in the manual. Output is varying between "good" lines and broken lines. On some pages, no printing occurs.
  • b_saitofamil May 11, 2010
    I spoke with a local (releatively) repair person. He said that the problem is most likely with the "board" in the printer. He also said that he did not think the board was available anymore since the printer is so old. Unless your experts believe this information is erroneous and that you can help me fix the printer, I would rather not pay an additional fee to find out the same information. I do like your service/product and will probably utilize you in the future.
SOURCE: Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Posted on May 16, 2008
jonniewalker
  • 1031 Answers
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
Posted on May 17, 2008
Roop1980
  • 228 Answers
SOURCE: My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Posted on May 09, 2009
rtrahan
  • 741 Answers
SOURCE: Have a Lexmark Z22 printer that skips lines while printing
One of your cartridges is plugged up..take it out and gently remove any excess ink from each cartridge hole with a napkin and try again..
Posted on May 28, 2009
  • 232 Answers
SOURCE: My Lexmark x1150 printer prints blank pages.
Usually, when the printer prints, but the page comes out blank, the print head on your cartridges is clogged. Since you pointed out that you computer was repaired, I guess you weren't printing during that period, so it is quite normal that the cartridges won't print. Here is a link to Lexmark's site.
http://support.lexmark.com/index?page=content&id=HO1562&actp=search&viewlocale=en_US&userlocale=EN_CA&segment=SUPPORT&productCode=LEXMARK_X1150&searchid=1270554483928.
Read carefully and follow the instructions. If necessary, do several nozzles cleaning, but do bear in mind that it uses a lot of your ink.
If you found my answer useful, please vote and leave a comment, that's what makes it all worth while!
Posted on Apr 06, 2010
Lines are visibile across the page every time i print something.Ihave tried changing catridges but makes no difference could you please give me some advice thankyou
If the cartridge is not the issue, then the printer itself most likely is. Usually lines appearing when you print is a sign that your printer is aging and needs replacement. If you've just purchased it it's probably defective. Otherwise, it's probably just getting old.
You might be able to check and see if there is any dust or stuff caught in the printer, if that's the case spraying it with compressed air to clean it might help. If not you should consider buying a new printer, or getting it replaced.
Mar 12, 2011 | Lexmark JetPrinter Z22 Color InkJet
How do I install Lexmark Z22 onto my Windows XP Pro computer?
Download the driver from the lexmark website located here.
After you download it then go into the add printer wizard and install the driver from there.
Sep 22, 2010 | Lexmark JetPrinter Z22 Color InkJet
I have installed a lexmark z22 printer but it
Try the following check-lists
1.Initially ensure correct drivers are installed in the operating system you are using .This can be checked by seeing in the device manager or in the control panel-->printers and drivers option.
If drivers are correctly installed you will the printer symbol in printer options with the name of the printer.
Right click the printer and give test page as print
If the print is not working check whether the power cables and connecting cables are good.
Check the indicators in the printer does it shows any warning.if you have manual of printer you can verify from it
Mar 10, 2010 | Lexmark C533DN InkJet Printer
I want to install lexmark z22 without cd. how can
You could try going to lexmark.com and see if tey have any way of doing it on line otherwise you may have to purchase a disc from them. Most printers you can get updates and drivers (sometimes) on line otherwise you need the actual disc to install the printers on your computer.
Nov 12, 2009 | Lexmark JetPrinter Z22 Color InkJet
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
Add Printer
The Z22 does not appear on Lexmarks vista compatability list and so there is no specific vista driver.
There is a driver for Windows XP which you could try
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=227:1:0:0:0:0
Select Z22 as printer model and search
then choose windows XP from the list of operating systems
Nov 23, 2008 | Office Equipment & Supplies
Lexmark Z22 Printer Problem
It´s probably a configuration problem , ralated with the parallel port settings. Tell me what Operating System are you using.
May 02, 2008 | Lexmark JetPrinter Z22 Color InkJet
New cartridge won' t print.
Was the cartridges lexmark factory replacements or was they generic replacement cartridges.
If they are generic cartridges you might want to buy lexmark cartridges because some generic cartridges will not work in some printers
Mar 03, 2008 | Lexmark JetPrinter Z22 Color InkJet
CANNOT INSTALL Z22
llucola:
The spooler service can be started following these directions.
Go to start
Go to run
In the open box type: <cmd> without <>
When the command prompt opens
type: net start spooler <Enter>
This should say that the spooler has started successfully.
Jess01: A driver is basically a communication device between your print device, which is your hardware "meaning can touch it" and printer software that is the language that your print device and computer can read. Your USB cable let's the computer know that your printer is connected. The software is needed so the printer has the language to be able to print what you tell it to.
If you have windows 2000 or xp.
Go to this website.
http://www.nodevice.com/driver/Z22_Color_Jetprinter/get31830.html
Scroll down the page 'til you find Lexmark Z22 Color Jet Printer
To the right you will see "download"
Click the link.
Scroll to the bottom you should see "Please enter verification code"
Type the code in and click "download"
Click save.
The software should then be downloaded to your computer.
Go to the location you saved the printer drivers.
There should be a setup file.
Click on that.
The printer should then be recognized and you should be prompted that the printer is going to print a test page.
Nov 05, 2007 | Lexmark JetPrinter Z22 Color InkJet
Lexmark JetPrinter Z22 Color InkJet Logo
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
