Question about Cycling
Wipers not parking - Cycling
    Scholar:
  • 75 Answers
Remove the nut holding them on, then remove the wipers and reset in the parked position and put nut back on.
Posted on Nov 12, 2009
Wipers dont work
This is a complex wiper system . Here are all the components involved !
The Wiper/Washer System consists of the following components:
Windshield wiper/washer switch
Body control module (BCM)
Wiper 1 relay
Wiper 2 relay
Wiper diode
Windshield wiper motor
Windshield washer pump
Windshield washer nozzles
Windshield washer solvent container
Windshield wiper arm and blade assemblies
Windshield wiper transmission
WIPER/SW 10A fuse
WIPER 25A fuse
Circuit/System Description
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation. The windshield wiper motor park operation is controlled by the BCM. The BCM recieves an input from the park switch to determine wiper blade position. When the wiper blades are at the bottom of the windshield glass in park position the wiper park switch will open and the circuit will be pulled up to B+ by the BCM. The park signal will be pulled to ground by the wiper motor park switch while the wiper blades are not in the park position.
The BCM controls the windshield wiper motor through two output controls, controlling two relays which determine the desired wiper speed, high or low
Diagnostic Trouble Codes (DTCs)
The body control module (BCM) monitors the voltage on the windshield wiper switch signal 2 circuit for diagnostic purposes. If the circuit is shorted to voltage while the driver is commanded OFF, the BCM will store DTC B3715. If the circuit is shorted to ground while the driver is commanded ON, the BCM will store DTC B3715. Refer to DTC B3715.
It would be best to have a factory scan tool to diagnose this problem . it would make it easier anyway .
It
Dec 05, 2015 | Cars & Trucks
2007 Pontiac g6 wipers stay in upright position
Hey Derek , here is how the wipers park position is suppose to work !
Windshield wiper motor park operation is controlled by the body control module (BCM) using an input from the park switch within the wiper motor assembly. The BCM monitors the windshield wiper motor park switch circuit to determine if the windshield wiper blades are at the bottom of the glass. The circuit will be pulled to ground by the wiper motor park switch while the windshield wiper motor is operating. When the wiper switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the BCM will continue to operate the motor until the wipers reach the park position. If the ignition is turned OFF while the wipers are in mid-cycle, the wipers will stop immediately where they are. The BCM will park the wipers the next time the ignition is turned ON.
The wipers will not park when they are commanded ON and OFF with a scan tool. The BCM will park the wipers the next time the wiper switch is turned ON and OFF.
The BCM provides stall protection for the wiper motor by monitoring the park switch. If the park switch does not transition for 3 seconds while the wipers are operating, the BCM will assume that the wiper motor is stalled, and will de-energize the wiper relay until the wiper switch is cycled OFF and ON again.
Check for a voltage signal on the yellow wire at the wiper motor assembly , this is signal to the BCM ! If there is no signal you need to replace the windshield wiper motor assembly ? If there is a signal need to have Tech 2 scan tool hooked up to see if The BCM is the problem ! Relay #39 an #40 are the high an low wiper relays in the under hood fuse block ! Do you have a volt meter ,do you know how to do electrical testing ?
Sep 21, 2015 | Pontiac Cars & Trucks
Can the wiper linkage cause the wipers to park vertical. Wipers work fine on all settings. Tried repositioning the wiper arms but it didn't work
normally if the wiper arms park in the wrong place , it is the fitting of the wiper arms on the pivot that is wrong
try pulling the wipers back off the windscreen , run them through a cycle and then switch off normally
that will be the park position in the motor gear box
then remove each arm from the pivot and re- position it about 1" from the bottom of the screen
that will be the parked position for the wiper blades
having done that then again pull the arms back of the screen and cycle as if wiping the screen
switch of and see where the arms now park on the screen
if it is close to where you set them then that is the park position
next run the wipers a cycle and see if at full movement one arm puts the blade over the edge of the screen or hits the edge
switch off and re-position that arm closer to the bottom of the windscreen
it is time consuming but the only way to park wipers properly as there is no master spline to set in the correct position
If they park any where after this exercise ,replace the wiper unit as there is a problem in the contacts in the motor box.
Sep 14, 2015 | Cars & Trucks
Monowiper works fine when in full wipe but when in intermittent wipe and park mode it stops 3 inches too high ??
It sounds like the wiper parking position relay has failed. You see, when you turn on the wiper a series of relays on the actuator side are energized and cause the wiper motor to turn on and move the mono-wiper through its arc.
When it reaches the maximum extent of its travel, the wiper circuitry then reverses the arms direction and it swings back. This goes on until you turn off the wipers by turning off the ignition key or turning off the power switch.
When you turn off the wipers, the parking circuitry is activated. The central feature of this part of the wiper circuitry is the parking position relay. As the wiper begins to de-energize the parking position relay is activated. The position relay ensures that the wiper returns gently to the same position each time you turn off the wipers.
If the parking position relay weren't there, the wipers would park wherever they stopped on the windshield. However, the relay circuitry charges when you hit the off button and ensures that the wiper arm sweeps down to the same spot each time. If it does not activate, the wiper arm stops as soon as you turn off the power, as noted. This means that the wiper might, one time, stop in the center of the windshield or it might stop all the way to the left of right.
Aside from its complete failure, manufacturers build in telltales that indicate when the circuit is about to go. One of them is the wiper blade's parked position. Normally, the position relay ensures that the de-energized wiper circuit settles gently to the bottom of the windshield, as noted. However, if the position relay is failing most manufacturers have it park some distance from the bottom of the windshield to give you a head's up that the relay is on its way out.
Since the wiper circuits are fairly involved, it is best to leave it to a trained professional to do the work. However, if you feel you have the expertise to do it, your first step is to obtain the serviced manual for your vehicle. The service manual will give you the step-by-step repair procedure.
Since all parts of the wiper circuitry are related be careful, if you are repairing it yourself, that you replace each component according to the instructions as you might damage something else inadvertently.
Nov 12, 2014 | Cars & Trucks
Fix monowiper park position on mercedes c 200 class
Does the wiper sweep past the park correct park position before parking or does it just never go low enough. If it doesn't go low enough, simply loosen the wiper arm from the transmission and lower the wiper arm to the correct park position. If it sweeps past the park position you need to disconnect the motor from the transmission when the motor is in the park position. The move the transmission to the park position and reattach it to the motor.
Sep 29, 2014 | 1999 Mercedes-Benz C-Class
Wipers would not park, customer forced down wiper arm and broke off arm. Now no electric to wipers.
Before 1995 Ford interval wiper systems mainly consisted of a switch, the motor and the interval governor (also called the wiper control module or 'WCM'). The basic wiper systems just parked the wipers at the end of their travel at the base of the windshield and involved just one park switch.
The more complex systems not only stopped the wipers at the base of the windshield, but would actually recess them below the windshield to park them. This involved using two park switches to turn the wiper motor in a reverse direction. These were installed on the Crown Victoria, Grand Marquis, Town Car, Taurus and Sable.
The wiper switch (named 'Multi-Function Switch' on most models) had a common return or ground circuit and two input or signal circuits to the WCM. Basically, the switch was two modified potentiometers that varied the resistance to ground for the two signal circuits. When the wiper switch was placed in the low or high position, the WCM looked at only one of the circuits- the 'mode input' -and controlled the wiper motor accordingly. If the wiper switch was placed in any of the interval positions, the mode input told the WCM that the switch was in an interval position. The WCM then looked at the second input - the 'delay input' - and used it to determine the amount of delay between wipes.
1) To run the wipers on low or high speed, the WCM provided constant power to the wiper motor on the proper circuit to provide the requested speed. Dual park switch motors
1.1 The first park switch operated basically in the same way as the single switch systems.
1.2 The second park switch worked in the opposite manner- when the wipers were off the park position, the second switch provided a ground for the wiper motor. Power and ground were now provided by the park switches.
1.3 When the wipers needed to park, the polarity of the switches changed, and thus provided reversed voltage to drive the motor in the opposite direction.
2) To run the interval wipers, the WCM applied voltage to the wiper motor only momentarily to get the wipers off the parked position.
3) The electro-mechanical park switch made a circuit between the power feed in and the output to the WCM. Power was provided from the park switch through the WCM and back to the wiper motor.
4) When the wipers reached the park position, the park switch made a circuit between the ground and the output to the WCM, and the motor stopped running. The wiper motor and the wiper switch have remained much the same as the single park switch motors of the past.
The main difference is that the switch has become an input to the GEM instead of the WCM.
1) When the wiper switch is placed in the low or high position, the Run-Park relay is grounded by the GEM to provide constant voltage to the High-Low relay, which then provides voltage to the proper circuit of the wiper motor.
2) High-Low relay is in the low speed position unless grounded by the GEM.
3) The park switch not only feeds the Run-Park relay but is now also an input to the GEM. This tells the GEM when the wipers are in the parked position so it can de-energize the Run-Park relay.
4) When any of the interval positions are selected, the Run-Park relay is momentarily grounded to get the wipers off the parked position
5) The park switch then provides voltage to the other set of contacts in the Run-Park relay.
6) When the GEM de-energizes the Run- Park relay, voltage is still provided from the park switch to the High-Low relay and the wipers complete the stroke.
Click over diagrams for zoom:
Hope this helps.
Feb 08, 2011 | 1993 Mercury Grand Marquis
Wiper arms do return to home position
there is a part an the wiper motor called a park switch that can be replaced but i dont recommed it i would replace the whole wiper moter to start with u will be money ahead......hope it helps
Nov 23, 2010 | 1999 Mercury Grand Marquis
Wipers wont go off
When you turn off the switch, there is a second switch in the wiper motor that continues to run the wipers until they are parked. If the window where that switch does not keep the wipers running is too narrow, the momentum of the motor turning will carry the wipers past the end of that window—they will continue until they are not-quite-parked. But not-quite-parked, in an absolute sense, is not parked at all, and that switch will reestablish contact, running the wipers to try to get them to the parked position.
Once there, the overrun happens again, and the cycle repeats.
Beyond that, if that switch gets stuck it will keep running the wipers, parked or not.
Sometimes the wiper motor can be easily accessed, opened up, and that switch can be serviced and properly adjusted. Sometimes the motor needs to be replaced.
Find the connector that runs the wipers, and disconnect it while the wipers are running. The blades will stop where they are.
intermittently, and briefly, reconnect the wipers trying to get them to move only 5 or 10 degrees at a time. This will avoid the motor get up a head of steam. If the wipers stop responding to this once they are parked, the window that the switch considers "parked" is too narrow. If they just keep responding to the application of power, even when they are really in the parked condition, then the switch has arced shut.
Jun 19, 2010 | 1995 BMW 5 Series
Wipers willnot return to park position
I've fixed this problem before. You have to disconnect the wiper transmission from the wiper motor. Put wipers in off position, unbolt the plate on top of wiper, turn wipers on then off. In the off position see where the wiper transmission is position in relation to where the park position is, remove the top plate from wiper motor and position it so as to be able to reconnect the wiper transmission now in the proper place. Please keep me informed. thanks you
Jun 03, 2009 | 2002 Chevrolet Impala
02 audi a4 quattro wipers won't park
If you can move the wiper arms by hand then the 13mm bolt on the motor has worked loose, remove the plastic windscreen trim under the bonnet , close the bonnet , then operate the wiper motor for 1 cycle , switch off , open the bonnet , loosen the 13 mm nut on the wiper motor , push wipers down to the park position , tighten 13mm nut up , close bonnet then check wiper operation , they should now park in the correct position .
Apr 14, 2009 | 2002 Audi A4
Cycling Logo
42 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
