Question about Dell 5110cn Laser Printer
Is transfer roller available separately. dell only sells it with imaging drum
It does work we have both models and the transfer rollers are interchangeable between the 5100 and 5110.
Posted on Nov 18, 2009
Search Dell store for M7077. This is the transfer roller for Dell 5100CN, sells for $29.95.
As far as I know this transfer roller also works with the 5110CN - I assume that it does because the package for the transfer roller that came with last image drum/transfer roller kit I ordered for my 5110CN says "5100CN"
Posted on Oct 13, 2009
Phaser 8860 prints only on left side of the paper, leaves perfect image on drum of right side.
Dear
As per your statement the image formation on drum is ok but prints partial on paper.
The image from the drum is picked by ITB (Inter Transfer Belt) which is a thin plastic like material and the paper passes in between the transfer roller and ITB.
If the ITB unit is not properly aligned to the transfer roller or to the drum the problem will occur as you mentioned. Also check the transfer roller and it contact path.
Thanks.
Jan 13, 2015 | Xerox Phaser Office Equipment & Supplies
How to clear a code
Sir/Mam
Open close the front door. if it comes back the charge corona wire above the drum or the transfer & separation wires are the problem. The charge wire is above the drum have to remove the drum section to see it they are very thin gold plated wires that place a electrical charge on the drum prior to the image being placed on the drum.
The Transfer and separation wire are directly below the drum Transfer allows the image to be placed on the paper as it comes underneath the drum and above this very thin gold plated wire, The separation wire the second one prevents the paper from sticking to the drum. The xfer/sep assy. wires are located directly under the drum. then are very thin mite be broken. Grounding the High voltage. pull down and pull out the assy. to check it. There is cleaning handle try pushing it back and forth. If they are broke replace tem very carefully. Percission Roller may have them
Apr 21, 2014 | Minolta EP4000/5000 CS/PRO Copier
Ep3000 how to clear a code co200
Sir/Mam
If available
What does opc belt do ?
OPC Belt (Organic Photo Conductor)
A photoconductor is a material that conducts electricity only when exposed to light. Photocopiers and laser printers have a large roller or belt coated with photoconductive material. As this drum turns it is electrically charged by a high voltage corona wire. The next step is to reflect an image using a laser beam or reflected light from mirrors onto the drum as it turns neutralizing the charge where light hits leaving a latent image or static charge in the shape of the image you want to copy.
The next step is to turn the roller past a brush made of toner (colored plastic particles). The static charge will pull the particles onto the charged area of the drum forming an image you can see, next feed a piece of paper onto this turning drum, as you do apply an opposite charge using a second high voltage wire (transfer corona) to the back side of the paper, causing the paper to stick to the toner/drum (opposite charges attract). Separate the paper from the drum using a high voltage alternating current (separation corona wire). Melt the toner into the paper with hot rollers. This will create a black and white image.
Jun 17, 2011 | Brother MFC-9420CN All-In-One Laser...
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
Printed image repeats later
I have a Dell 5100CN, and believe that this problem is caused by the drum not releasing the full charge which holds the ink in place on the drum until the page is printed. After the image is transfered to the Drum, the 'Fuser' unit heats up the paper and pressure forces the paper against the drum to transfer the toner from the drum to the paper.
Since the Image is printing, and you are getting a ghost, I guess that the problem is most likely the 'Pressure Roller' or 'Heater' in the 'Fuser' unit.
Buying the Fuser unit from Dell could cost you around $200 from Dell, but I just found one on eBay for $129 Got to www.ebay.com and search for item number 190388919845
I highly recommend that you buy a new OEM (original Equipment Manufacturer (Genuine Dell)) 'Fuser Unit'
Good Luck
Apr 23, 2010 | Dell 3010cn Laser Printer
Kyocera fs 4000 how to replace drum, transfer roller and pickup roller
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Feb 04, 2010 | Kyocera FS-4000DN Laser Printer
Buying and replacing just the transfer roller on a Dell 5110cn
Maybe if you call you can order just the transfer roller. You could try removing it and cleaning the ends (to provide better electrical contact). You could also try wiping the roller itself with a lint free dry cloth - but do so at you own risk and never touch the roller with your fingers!
Dec 09, 2008 | Dell 5110cn Laser Printer
Dell 5110cn Laser Printer Logo
697 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
