Question about Toshiba Satellite A100-S8111TD Notebook
Anything that i was searching that still remains on the down arrows
  • James Chavez May 11, 2010
    If you would please describe your situation in full detail. I am sure I can help you it you provide me additional information. JimmyC
  • 591 Answers
Try opening IE, clicking on Tools, then Internet Options, then Delete Browsing History, then Delete History and the searching history will be gone after closing all the windows out.
Posted on Oct 03, 2009
How to activate touchpad on acer e1-571
Hi
One of the toggle switches using the FN key turns the touchpad on and off.
<Fn> + <F7> Touchpad toggle. Turns the built-in touchpad on
and off.
If you go here :-
Drivers and Manuals
and selecting your model from the selections offered ie "Notebook" then "Aspire" then "Aspire E1-571" you can find all the documentation, drivers, applications, BIOS etc for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | Acer Aspire Computers & Internet
Why is my TI-83 screen black?
If you cannot see anything on the screen, the contrast may need to
be adjusted.
To darken the screen, press 2nd and release, and then press and
hold up arrow until the display is sufficiently dark.
To lighten the screen, press and release 2nd, and then press and
hold down arrow until the display is sufficiently light
Apr 15, 2013 | Texas Instruments TI-83 Plus Calculator
How do i convert from bing back to google. I have Windows XP
In Internter Explorer look at the top right search area and you'll see the Bing logo near a magnifying glass icon, Further to the right straight up from the scroll bar, you'll see another magnifying glass icon (smaller size) and a drop down arrow to its right. Left-click the drop-down arrow and selet Google. The Google name should now replace the Bing logo for search default. On Firefox it's essentially the same process, but the drop-down arrow is on the left of the search window and to the left of the search engine icon.
Jan 17, 2011 | Microsoft Windows XP Home Edition
My printer is set up wirelessly and will not print. How can I check to make sure it is online?
On the printer itself push the setup button (the one with the little wrench)
Then push the down arrow key until it network is highlighted and press ok.
Then view network settings should be highlighted. Press ok.
Finally push down arrow key to WIRELESS network settings. The main thing you are looking for is the IP address. If it says Not applicable, 0.0.0.0, or anything starting with 169 then the printer is not on the network.
If it is off the network you should be able to hit the cancel key (red X) a couple times to take you back to main screen.
Then push down arrow key to wireless setup wizard. Press ok.
It will search for your network and ask for the password if you have one (it is case sensitive). When completed it will be on the network.
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
Screen remains blank at start-up
This seems weird but it DID work for me!
It saved my EEEPC 900HA from the same problem.
Here's what I did:
-Remove ac adaptor
-Remove battery
-Hold Power buttton for 32 seconds (yes I know its weird..)
-Remove bottom cover on laptop to reveal memory.
-Remove memory CAREFULLY (move metal tab either side that is a bit springy to release & place memory on table without rubbing or touching it apart from edges)
-Look at circuit board where memory was installed.
-search for two very small copper arrows right next to each other (they look like elevator some up & down arrows)
-Use a small screwdriver to "short" the arrows (touch both arrows at the same time - for at least 5 seconds)
-Re-install memory
-Replace botom panel & battery
-attach ac adaptor
-power on
If you see the gray screen - it worked.
As far as i can tell this process resets the bios so make sure to enter the setup and check your time and date.
Good Luck. :)
Aug 14, 2009 | ASUS Eee 4G Notebook
What is the symbol with the light indicator for?
That's the Scroll Lock indicator.
While not really used for anything today, Scroll Lock used to serve a purpose in DOS text editors - if it was on, and you'd press the Down arrow on your keyboard, the document would scroll down. If it was off, you would move your cursor to the line below it.
It should also work on Microsoft Excel - try it. Open up Excel, make sure Scroll Lock is on, and press the Down or Up arrows. Now turn it off, and see what happens.
If you don't know how to turn it off, search for a key marked "Scroll Lock" or any short versions of that name. If it's in a different color, you may need to press Fun+ScrollLock for the light to go off.
Aug 10, 2009 | HP CPQ175KB Keyboard
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
Jul 29, 2009 | Televison & Video
Acer 1690 keyboard arrows problem
Sounds like your number lock maybe be on. It could also have a shortcut function option that is on. If not, have you spilled anything on it lately?
Mar 22, 2009 | Acer Aspire 1690 Notebook
HELLLLPPPPP
First Remove the UMD from PSP if any
1. Switch ON the PSP 2. Press and Hold the Left arrow button until the Sound of "click" Stops. 3. Press and Hold the Up arrow button until the Sound of "click" stops. 4. Press the Down arrow button 4 times (so u will be in System Settings) 5. Press the Enter Button i.e X 6. Press the down arrow button 9 times so u will in "Restore Default Settings" 7. Press Enter button i.e X once 8. Press the Left arrow button once and then press X button once 9. Press the Left arrow button once and the press X button again 10. Press the X button
See whether u r PSP restart and solves the problem
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Toshiba Satellite A100-S8111TD Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
