Question about SanDisk Sansa e250 MP3 Player
My computer does not detect my sansa e200 on d my computer
Although it isnt detected on my computer, in the device manager it shows dat the there no drivers installed.. i tried reinstalling the drivers but no use.. what 2 do??
  • 10,421 Answers
Tip
For Version 2 Sansa E200 Series and Version 2 Sansa C200 Series
As you have notice, these version of player will not have the USB Mode / Mode ( FOr Rhapsody Players ) and / USB for sansa C200 series. If you want to have your player detected by the computer as a removable disc drive or as a MSC drive you can perform this easy steps.
For Sansa E200 Players and C200 version 2 Players.
1. Enable the Hold Switched for it to show a red color.
2. Press and Hold the Rewind button the " << " then connect to the computer.
3. Connect the player to the computer and dont let go of the Rewind Button " << " , you will notice that the player would be detected as a removable drsc drive in the My Computer Window.
*For Load Main Image Failed Problems and player Freezing on the Refresh Database Screen will be post later*
on Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
I cant get in my computer but its showing in device manager
As you tell the device in can only be detected in the device manager.
It can not be seen as a removable disk in MSC mode and neither in MTP mode, showing as media player with the Sans icon.
Consult next page about 'player not being recognized':
http://kb.sandisk.com/app/answers/detail/a_id/42/kw/manager/r_id/101834
Refresh the drivers or manually ad the driver for the player as described.
Sansa manual for e200 series (version 2):
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
Important:
1. Check the system requirements of the computer as described in the manual on page 8 of the file [=page 5].
2. Charge the device using an USB connector directly to the computer,
not through a hub or card reader, preferred at the back side.
If more help is needed, just post a comment.
Sep 28, 2009 | SanDisk Sansa e250 MP3 Player
NO AVAILABLE PLAYER DETECTED!
Try going into settings, usb mode change that it should be either mtp or msc.
May 09, 2009 | SanDisk Sansa e200 MP3 Player
System is not searching the player
ok.i have the solution for you...go to CONTROL PANEL after to DEVICE MANAGER but keep your device conected ,,it will detect your device like herror just delete it and desconect your device and conect it again and follow the steps..good luck.
Nov 14, 2008 | SanDisk Sansa e200 MP3 Player
Not detecting the mp3 player
its probably just ur player has messed up, because everything else i plug in works with no problem
Apr 27, 2008 | Philips HDD082 MP3 Player
Songs are not being show (not getting detected) in the music list
k i had the same problem twice,
the first time i couldnt fix it because i ended up getting a device read error when i tried to acces it in my computer, but i think whatever caused that was different than the second time.
this time my device retained all the songs origionally on it but wouldnt reckognize any new songs. In addition to that, when i deleted all the songs off the player and only put a couple back on the player didnt register those either. so it would seem to me that it is a problem with the device's database refreshing algorithim...although thats just a guess.
neways...to fix it i copied all the data & folders off the sansa (including the .txt and .sdk files) and stored them on my desktop. After that I tried the e200 firmware upgrader available at sandisk.com
After messing around for 2 hours trying to figure out what was going on i deleted all my music, videos, recordings and pictures off the device and proceeded to format it in msc mode.
after the format was complete, i re-copied the data i had backedup on my desktop and pasted it back onto the sansa.
it seems to have worked...but then again i still don't know what caused the problem so it may not work for you. (i think it may have been something to do with one of my music files since both instances happened after i uploaded the same 5 songs onto the player)
also, i had numerous virtual folders & files that had conflicting sizes and would not open when i clicked on them (windows says they had +4GB sizes but properties says 0B also when clicked i get a file not found error).
hope this helps.
Nov 22, 2007 | SanDisk Sansa e260 MP3 Player
Can you fix my sansa e200
hi
    Are u able to see the Sansa player detected under mycomputer
or whether is it getting detected under device manager. once i tried connecting sansa device in msc mode it got detected under device manager so i was able to reinstall its driver u can also try that
also respond to my email address at balista2003@gmaill.com
Oct 13, 2007 | SanDisk Sansa c150 MP3 Player
My computer wont detect my e200
Dont turn it on and plug it in. That had happened to me and that fixed it.
Aug 31, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
