Question about Refrigerators
I hear the motor running, but its unable to freeze ice or even keep water cool, this has been going on since a week.i've had the compressor cleaned and dusted, but to no avail
  • 58 Answers
Take the back panel out of the freezer and see if it is solid ice behind it. The defroster heating element burns out and the evaporator coils freeze over and then no air can flow through them. usually cost less than $50 and takes about 20 minutes to fix.
Posted on Oct 02, 2009
Testimonial: "i haven't spoken with the technician yet, but i guess this sheds new light on what i was thinking all along..thanks!"
  • 4,059 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
Hi. We moved to a house with an integrated Teka A-FC1359 Fridge/Freezer. It was working fine. We switched it off 3 months ago. Now we've swithched it back on but it's not working.
It can be issue with faulty compressor capacitor.From main power outlet the power goes to capacitor beside compressor and from there power goes to compressor motor,then after that all unit works.May be that capacitor got shorted or loose from its actual connection.Or other possibility is faulty power wire of refrigerator.Get the wire checked with continuity tester to confirm its not broken in between.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have a kenmore model # 106.54582400 that has been moved and not plugged in for 3 months , i cleaned it all up like new and plugged it in and now its not cooling , its never been on its side , the motor...
The compressor freon got leaked or compressor got damaged while shifting.Get the compressor inspected.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Kenmore Refrigerators
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I would like to ask for some info and troubleshooting techniques in which my refrigerator samsung model number RT22S. I noticed that the water inside the water bottle container is freezing and most likely...
Its not normal.The problem is related to defrost.Unplug unit from power outlet for 12 hours and then reconnect it and start.These resets the refrigerator.But its not working even after reset then internal defrost assembly and condenser/ compressor needs inspection.
repairclinic.com
partsselect.com
These will help.
Thanks,.
The freezer section seems unable to get to -18 degrees in for the past couple of weeks, even on Super freeze. It has been fluctuating between -11 and -14 for the past week with Super freeze setting on...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 01, 2011 | Refrigerators
Not cooling or making ice - fan and lights OK
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
iufgh
Jan 12, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Refrigerator not cooling although lights and sound are OK
heatman101
\ fbvb
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not...
hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Sep 26, 2008 | Refrigerators
Refrigerator, s/side, too cold, etc
unplug and let defrost. You should also clean the grills off in back and get all cob webs off from underneith. that might help
Apr 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
