Question about Kitchen Ranges
Wont heat under 225 degrees
My model number is JES9750BAS Serial # 18311793PA
It will not heat under 225 degrees.......what if I want 150 degrees
    Sergeant:
  • 197 Answers
Could be your thermostat
Posted on Oct 03, 2009
Finding year from a ssrial number on a mercury out bord
go google and type in--- mercury outboard serial numbers -- there are sites that listhp against serial numbers against year of manufacture
while you serial number may not be listed they state that the beginning of the number to the next changing number is the year of make
for example ---4261012 to 4302999 ( next number 48103665,year 2002) may be year 1999 so your number would be a 1999 model
The information provided will take a bit of understanding as it appears that the manufacturer changed the method a number of times
talk with a mercury / mariner service shop as they will have the information on hand
Sep 26, 2016 | Sierra Tilt/trim Motors, Outboard...
When I press the Bake Button it only heats to 175 degrees instead of 350. Using the temp up Button the maximum heat is 260 degrees. How do I return to the proper settings?
Hello Jim;
My name is Peter. I am a retired Sears Home Services/A&E Factory Service field service appliance technician.
The information in regards to your model number does not match any known range. The model number is on a metal plate on the face of your oven when you open the door.
There are several components that effect the control of your oven temperature.
1.) Is your oven electric or gas?
2.) If electric do you see any sparking on the heating element?
3.) Does your broiler work?
I really do not know what you have. Give me the model number or call me @ 443-306-1362 and I will try to help you.
Peter Goodwin
Glen Burnie, MD
Jan 30, 2015 | Kitchen Ranges
I have a Mexican made Fender Stratocaster guitar with the serial number MX10070942. All I want to know is what the value of the guitar is???
Standard Model: 175-225
Deluxe Model: 225-275
Signature Series: 350 -600
Of course,the condition of the instrument and accessories (case etc.) will vary the price.
Jul 24, 2014 | Fender Music
Masterbuilt Smokehouse model 20070712 won't smoke wood chips at 225 degrees
I had this exact same problem with my Masterbuilt Smokehouse even when brand new. I notice there is some variability in the space between the top surface of the heating element and the bottom surface of the wood chip box. I measured about 1/4 inch between the two surfaces when the heating element was seated bottomed out and touching the wire grill below it. What I did to fix the problem was to gently (make sure everything is completely cold before doing this) lift up the end of the heating element farthest away from where it enters the enclosure just a little bit so that when you put the woodchip box in where it is supposed to go, the top surface of the heating element will now be in contact with the bottom surface of the woodchip box. This arrangement allows much greater heat to heat the wood chips during the part of the heating cycle when the heating element is on (naturally the heating element cycles on and off to regulate whatever temperature your are targeting for your food being cooked). Now, because of this contact, every time the heating element comes on, enough heat will enter the woodchip box to keep the chips ignited. My next step is I am going to put a small 1/4 inch thick piece of metal beneath the heating element and the rack that is under it to force the heating element to stay sitting 1/4 inch higher so that it is always in contact with the lower surface of the woodchip box. Making these improvements allowed me to continuously get smoke when the big smoke box was at 225 degrees F.
Without making this fix, the unit would stop producing smoke at 225. Hope this makes sense and helps you.
Aug 25, 2012 | Masterbuilt 20070106 Electric Smoker
My oven is loosing temperature
To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
Feb 10, 2012 | Ovens
Chức nÄ?ng và ứng dụng
ah this would be like speaking a differnt language that I dont understand what is the problem with your kitchen range? please also include model and serial number as well please write back so that I may assist you in fixing your range
Thanks again
RIck
Nov 28, 2010 | Kitchen Ranges
95 Jeep Wrangler YJ...No heat, temp at about
It should be 200 degrees. If your running cold the only thing that regulates temp is the thermostat. If it is indeed 150 degrees thats why you have no heat.
If you replaced the water pump and the radiator for this condition then it was a waste of money. If you had a water pump or radiator problem it would overheat.
The fact that your blowing cold air tells me the that you really are 150 degrees or the heater core is plugged.
Mar 10, 2010 | 1995 Jeep Wrangler
Have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Jan 13, 2010 | Rinnai Heating & Cooling
Bad sectors and fails under minor load
No it's not repairable. Copy any data you want from it to another drive, cd, dvd, etc. Go to www.seagate.com and fill out a warranty RMA form. If it's warranty you'll get a new one from Seagate
Jan 06, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
