Question about Samsung CLP 300 Laser Printer
Resetting printer after transfer belt change
I have a samsung CLP300 and replaced the transfer belt assembly as called for by the smart panel application. However the printer hasnt recognised this and still tells me to replace the unit. How can i reset this?
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
Posted on Jan 20, 2008
SOURCE: Transfer Belt vs Transfer Roller
Its a bogus message. Simply open and close the front cover of the machine. It resets it and the message disappears.
Posted on Oct 14, 2008
  • 9 Answers
SOURCE: my printer's(Samsung CLP300 Color laser)smart
If you allowed your cartridge to run completely empty before refilling, the chip on the cartridge "knows" it is empty and will not allow it to be used. You can buy replacement chips for about $6.00 or so or buy third party cartridges for about $15. Your cartridge is not going to work until you get the chip replaced.
Posted on Jul 10, 2009
picipolman
  • 9 Answers
SOURCE: replacement transfer belt on my Samsung CLX-2160 not recognised?
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Posted on Jul 28, 2010
How to fix transfer belt error in my samsung CLX3160fn
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
How involved is it to replace the actual belt on the transfer belt for clx-6200 fx printers? Without having to purchase an entirely new transfer belt?
I just bought a CLX-6200FX and it has holes in the transfer belt, so I think it's the reason I get poor color printouts. I just bought a belt (vs. an entire belt assembly) and am going to attempt to change it out. Any hints as to how to start would be appreciated.
Dec 01, 2010 | Samsung CLX-6200FX Printer
Washed out printing both in colour and text
check on your pc smart panel that is install for any error detect for your printer.
follow the the error to get it check is much easier.
hold and press on the button of the printer for 5 sec to check on the supplier infor. that tells you the waer and tear item to be replace.
advice is to replace the toner block (OPC) image drum
if you do not have a smart panel install. you may go to www.samsung.com -> support and download the smart panel program.
http://www.samsung.com/sg/support/download/supportDown.do?group=pcperipheralsprinter&type=printermultifunction&subtype=colourlaserprinter&model_nm=CLP-300&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010200&acc_ia_fl=&disp_nm=CLP-300&model_cd=&menu=download
select the correct version with your OS.
1. OPC image drum - 25K +/- 2. transfer belt 25K +/- 3. transfer roller 20K +/- 4. pickup roller 20K +/- 5. Fuser 25K +/-
Apr 05, 2010 | Samsung CLP 300 Laser Printer
Occasionally getting div.home error. any fix?
no you have to call the service. The Image Transfer Belt (ITB) has a sensor problem. you can't fix it on your own.
Oct 16, 2009 | Samsung CLP 300 Laser Printer
My printer's(Samsung CLP300 Color laser)smart panel says 'cyan empty replace the cartridge' even after refilling the cartridge.Not printing.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
Samsung clp300 color laser printer not printing
The cartridge dried out and the moisture/liquid sensor will no longer detect new fillings though the layer. A good refill needs to be done before the ink is out. These are tedious little critters. Try the nozzle cleaning procedure several times(through your printer's software. Take out the cartridge and set the jets on a cotton ball soaked liberally with cleaning fluid. Run the nozzle cleaning procedure again.
Jul 05, 2009 | Office Equipment & Supplies
Clp300 all red lights are on and priner gets hot wont print please help changed ink cartridges cleaned  out dump tray. still not work
Try installing the smart panel software from the samsung website and see if it tells you a specific message.
Apr 20, 2009 | Samsung CLP 300 Laser Printer
Reset transfer belt samsung clp-300
Sorry
J
Jan 08, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
179 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
