Question about Kenmore 24862 Top Load Washer
Hello, my washing machine will not spin or agitate. It makes a horrible sound. I bought it in 2001. model #:24862300 Serial #:CP4021766 This is the 80 series. There was a time where we had it in storage for 2 1/2 years, so I don't think its the age. They are in great shape. Could I have over loaded it? Thank you, Cori
  • 5,911 Answers
It sounds like you may have a broken motor coupling. This is actually a common problem that usually occurs through normal wear and tear. This could have been a result of being in storage, as well. There is a rubber bushing between the coupler pieces that could have dry rotted from sitting so long and simply sheared apart. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
Posted on Oct 02, 2009
My washer started to make horrible sound when it tried to agitate. After draining water n removing clothes i tried just starting from rinse cycle. It filled up. It agitated w horrible sound but will not...
mine did this to me, need a new agitator. dependin on the age of yur washer, might need a new washer. it is a decision up to you. I bought a new set in the end, cost of part & time to install. Besides the age of the washer was a consideration i considered.
Mar 08, 2015 | Washing Machines
Magtag MAV408DAWK washer is working, but horrible noise when Spin. Agitator works normally, though it has weak sounds, loudly horrible noise in Spin mode. All others are working well. What parts do I have...
Hello & Welcome to FixYa
The problem seems to be either with the brake assembly or the transmission assembly going bad and needs replacement. If the sound is loud then the recommended repair is replacing the transmission assembly however you can also check the brake pads, if worn out then they also need replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Maytag Washing Machines
Will not agitate or spin. it just makes a horrible buzzing sound
its either a broken drive belt (if it has one ) or the gearbox is either not engaging or is slipping
Jul 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
Both drum and agitator spin during wash cycle. Is this normal?
What is the age and model number of the washer? It could be as simple as a problem with a part inside the agitator or it could be a bad transmission. A complete model and serial number from the washer not the book.
Jan 10, 2009 | Washing Machines
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Sep 05, 2008 | Admiral AAV7000A
Kenmore 24862 Top Load Washer Logo
101 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
