Question about Dell TrueMobile 2300 Wireless Router (tm23003)
Address for my dell truemobile 2300 wireless router
The router says to type in my.router in the address line of my browers to get to the page to change my settings. This worked a year or so ago. Now what I get is many websites that have to do with a router.
  • 556 Answers
Several suggestions
First Try entering this into a browser.
http://192.168.0.1
If that does not work and you are using a windows box truy the following
STart then All Programs then Accessories then Command Prompt
In the new window that opens type the following line and press enter
ipconfig
This display should include a default gateway address
Try entering the following command into a browser
where you replace the {DefaultGateway} with the Default Gateway address from the ipconfig command above.
http://{DefaultGateway}
Posted on Dec 21, 2007
Where is the wps button
some routers dont have wps button but if you need to reset router To restart the Dell TrueMobile 2300 Wireless Broadband Router, unplug the power connector and plug it back in.
To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Jan 06, 2013 | Dell TrueMobile 2300 Wireless Broadband...
How do I secure my wireless router? dell truemobile 2300
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 21, 2010 | Dell TrueMobile 2300 Wireless Router...
I have a TrueMobile 2300 router and my security code is not working. How can I change it?
The only way to reset the password if you can't remember the old one is to reset the device. To load the Dell TrueMobile 2300 Wireless Broadband Router's default settings, hold down the reset button on the router for at least five seconds. While the unit resets, the Power light blinks.
Then navigate to the router through your browser and Type the following as your username:
admin
Type the following as your password:
admin
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Advanced Settings tab.
Click the Administration Settings button on the left side of the page.
Put a check in the box to the left of the Change Your Password setting under the section of the page titled Password Settings.
Type the password that you want to use in the New Password field.
Retype your password in the Retype Password field.
Click the Submit button.
Another window appears stating You have successfully submitted the settings to this device!
Click the Save and Restart button.
Your new password will be saved into the router settings.
This will however wipe all your settings!
Jan 05, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Installation software true mobile 2300
hello.. u can setup ur router even there is no setup disc.. check first the default gateway of ur router by connecting your computer directly to the router using an ethernet cable.. to check the ip gateway, click on start, run and type cmd, it will give u a dos prompt, from there type ipconfig/all and check the default gateway,ex.. the default is 192.168.1.1, close the dos prompt and pull up the internet brower from the url.. type in 192.168.1.1 and it will ask the username and password.. u need to enter it, by default the username is admin and the password, just leave it blank, if didnt work try 1234.
Aug 04, 2009 | Dell TrueMobile 2300 Wireless Router...
Dell Truemobile 2300 - cannot connect to internet
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Jan 26, 2009 | Dell TrueMobile 2300 Router (000001)
How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
192.168.2.1
Click the Go button.
You are prompted for a Username and Password.
admin
admin
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address 192.168.2.1.
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 02, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Truemobile 2300 router
You may need to enable the wireless signal within the router settings, but you will have to connect to it via an RJ45 lan cable, as you would of when you first set it up. Type in the routers ip address in your internet browser and get into the routers settings that way.
Mar 24, 2007 | Dell TrueMobile 2300 Wireless Broadband...
If you are able can you reset the router in any way normally little reset button on back, or get into the routers set up page and try a restart.
Oct 29, 2006 | Dell TrueMobile 2300 Wireless Router...
Dell TrueMobile 2300 Wireless Router (tm23003) Logo
172 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
