Question about Fuji DVC-80 Mini DV Tape
The tape broke, where can i bring to get fixed so that i don't lose the film i recorded?
  • tcote03 Oct 03, 2009
    thanks very much!
    President:
  • 2,049 Answers
If you decide not to do it yourself or can't find a local source to do it, here is an online solution for a company in Poulsbo, WA that can help...
http://www.pacificvideorepair.com/?referrer="Google"&gclid=CNDAkLjJn50CFR4Uagod40xqAA
Posted on Oct 03, 2009
    Novelist:
  • 157 Answers
I think you can take it to anyone that deals with video tape even some camera shops will splice video tapes back together. You could even do it your self by carefully disassembling the case of the video tape and taping the two broken ends back together with scotch tape if the two ends are ragged you should cut a small amount off to square the ends up and make sure you apply the scotch tape to the side of the video tape that doesn't contact the head of the video player. And remove all the slack before re-assembling. If you are afraid you might mess the tape up try dis-assembling one that doesn't have any video on it for practice to see if you can do this and you can use the one you dis-assemble as a guide.
Posted on Oct 02, 2009
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
Tip
I've been unable to play several bought VHS tapes of films, though oddly,...
Vcr's commonly get dirty heads that cause a blue or snowy screen and no sound in some cases. In my experience the rental tapes were common point of trouble especially when you consider the amount of machines that were deployed in use back in those days. Today people run into less issues because they have there own collection and put them to good use. In order to deal with some people's problems there are three approaches to cleaning heads, the first option is to use a wet tape with the provided fluid usually two or three drops will do and run it for ten to twenty seconds. The second approach is use a dry tape with same amount of time as outlined above. The third approach is get a blank store bought tape "T120 2hours" set the vcr to sp and run the tape from beginning to end, this is a good way if you want do more of a deep clean to remove difficult dirty particles that refuse give way. I find the dry tape will give less problems when cleaning and less chance of shredding and easier for people who don't like taking vcr's apart.
on Jun 02, 2011 | Televison & Video
Eject tape from panasonic AG-6810s
I don't know,but if u broke the tape then....
Jun 30, 2013 | Electronics - Others
How can i convert tapes to dvd
You can connect the Camcorder to the Computer using A/V interface to transfer the recordings to Computer.
Once you transfer the recordings from tape to computer, you can use any burning software to burn the recordings to DVDs.
In order to capture the analog videos, you can use the Windows Movie Maker available in the Computer.
If you need further assistance please click hear to reach me..
HOping a positive thump after your issue is solved.
Jan 13, 2011 | Sony Hi8 CCD-TRV138 Camcorder
In February, someone asked: "When
What are the tapes that you are trying to copy? are there genuine copies of films? YES THEY COULD BE COPY PROTECTED how they do that? simple they record the tape with the most minimum srength of signal, if you try to copy it you lose signal strength trough the copy process than the video looks a bit scrambled/discoloured and the sound is bad, if it's the case you could buy a video signal booster (if still available in stores) than you have to copy with a VCR that is separated from the DVD recorder so that you can install the booster from the output of the VCR to the input of the DVD recorder.
Hope it helps!
Jan 04, 2011 | Televison & Video
Camera won't record/ play footage.
Video head was dirty / clogged due to old tapes usage so it did not recorded any signal on tape and now it requires cleaning with good quality head cleaning tape to record and playback properly.
May 31, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Purple and green digital lines across film
One of the units is not making good interchange in recording (CAMCORDER) or (PLAYBACK) DSR11 deck either buy or get a known good recording to isolate the bad unit. Camcorders are notorious for loss of interchange as the cassette compartment wears out the scissors jack elevator gets sloppy and changes the angle of attack on the drum and wellah a tape that only plays back in the camcorder.
Jan 18, 2008 | Sony DSR-11 DV / Mini DV VCR
JVC video recorder - replacing rubber band
Not spinning disc If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A Unable to detect discs The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A) Dew indicator is on permanently. Cannot play or record tapes. No dew present - caused by internal fault This Camcorder uses very fragile flexible circuits to interconnect the PCB's. They plug in to edge connectors. It seems that when they made these camcorders at the factory, they had as many problems getting these film flexy circuits back into the connectors as us service engineers have. I saw one unit that had a crease in the flexy circuit which had caused a hair-line fracture. Solution, trace the wiring and solder a sub-miniature wire across the broken track. Don't disturb any flexy connectors that you don't need to. This camcorder is a **** to work on Not loading properly Usually due to incorrect head alignment or dirty head, or failure of LM324 op-amp Doesn't record properly, ie: looks like one channel is down when recorded, pre-recorded tapes are ok Check Q008 for dry joints
Nov 24, 2007 | JVC HR-J461MS VHS VCR
Cannot film
  Dear carooooo, You are dealing with tape not film. Your problem might be in your tape.   Try running your tape on record the full length. Keep your lens cap on. Color balance and use new tape that's for your Sony.         jameskeyboar.
Nov 04, 2007 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Fuji DVC-80 Mini DV Tape Logo
93 people viewed this question
Top Fuji Electronics - Others Experts
Are you a Fuji Electronics - Other Expert? Answer questions, earn points and help others
