Question about HP Officejet H470 InkJet Printer
The printer does not print. It is not paused,
The printer does not print. It is not paused, all cables are connected, I have reinstalled the driver several times, the green light on the printer is on and my computer beeps when I unplug or plug in the printer. But no printing.
JoAT
  • 121 Answers
SOURCE: HP1060 won't print
Have you looked at the front cover to see if the tab there is broken? (this will tell the PC that the front cover is still open) So you'll want to go around the edges of the printer cover to see if there's anything broken and a small hole in which the tab would insert into. If it is the case, and you don't want to spend money on fixing it, then do what I do...Rig up a paper clip and electrical tape to work as the tab, making the printer think that the front cover is always closed.
Posted on Mar 27, 2007
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
  • 72 Answers
SOURCE: printer pauses between each print job
Step one: Download and install the print diagnostic utility. click on this link from HP and download the printer diagnostic link. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?swlinkmsg=100&lc=en&dlc=en&cc=us&product=1153494
Posted on Jun 17, 2009
nalin_elliot
  • 224 Answers
SOURCE: HP 2840 printer pause will not resume
uninstall your printer and then re-install it that should fix your issue,it could be a bad version of an updated driver that is causing the problem
Posted on Jun 19, 2009
Printer paused issue
problem with memory issue try holding the power button while unplugged then connect and power again.
Nov 23, 2015 | PrintCountry Canon NP 3050 Laser Printer...
I can't get my printer to print. It seems to be stuck on Paused.
If your printer is connected via wireless network, please try the following.
1. Check if WiFi light indicator if enable and has signal strength.
2. Check if your computer is connected to your wireles router.
3. Reinstall the printer driver.
If your printer is connected via USB cable, please try the following.
1. Check if the printer and computer is properly connected.
2. (for Windows), Check Device Manager if USB Printing Support is present, (for MAC) Check Apple System Profiler if EPSON MFP 2.0 High Speed is present under USB device tree.
Nov 03, 2011 | Epson Artisan 800 All-In-One InkJet...
Everytime I send a document to our HP CP5225 printer the printer pauses. It is switched on and everyone else can print. I have tried reinstalling drivers but am now stuck for ideas :(
When you un-install and reinstall please have your Printer removed off- the cable taken off from the PC . Connect only after the new installation is done as the PC will recognize the printer as a new hardware and install.
hope this works or your PC has errors in the OS.
Apr 01, 2011 | Office Equipment & Supplies
Hp1020 printing is not working it says print paused...what should i do
Please make sure about its data cable because it is data cable issue. You can resolve if you can change its data cable otherwise replugged the data cable.
Thanks
Mar 03, 2011 | HP LaserJet 1020 Printer
My printer is paused and I can't get it to unpause.
Here are the problems due to which a printer gets stuck in pause and ways to fix it:
* Problems
* Reinstall drivers
* Verify Print Spooler service
Problems
There are several problems due to which your printer gets stuck in pause. Driver issues are considered to be one of the major problems as they allow printers to communicate with the Operating System of your PC. When there are problems with Print Spooler, your printer can get stuck in pause.
Reinstall drivers
In order to resolve the problems that occur when your printer get stuck in pause, as a first step, you will have to disconnect the printer and delete the printer from Device Manager. An outdated printer driver will also cause certain problems. Thus, you need to download the appropriate printer driver from manufacturers website and install it on your PC. It is also wise to update the driver frequently.
For More Detail
http://printers.iyogi.net/issues/printer-paused.html
Jan 22, 2011 | Office Equipment & Supplies
How to solve 'error S01'?
1. Verify USB cable is connected directly from USB port of printer and the USB port on back of computer. If not, connect directly to both the printer and computer and try to print. If the printer does not print, go to step 3.
2. VERIFY THAT THE BROTHER PRINTER IS SET AS DEFAULT
This is especially important if you use the print icon to print from within applications. If the Brother printer is set as the default printer, it will have a check mark. If it is not set as default:
To set your Brother machine as the default printer, RIGHT CLICK on the Brother printer and select SET AS DEFAULT (PRINTER).
3. VERIFY THAT THE PRINTER STATUS IS READY AND THE PRINT QUEUE IS EMPTY
A. Click on START, RUN
B. Type: CONTROL PRINTERS and click OK.
C. Locate the Brother printer in the list and hover your mouse over the Brother printer icon. Below is an example of what you may see:
Status: Ready (Could also state: USE PRINTER OFFLINE or PAUSED)
Documents: 0 (Could be any number)
D. If there are any documents waiting in the queue, right-click on the Brother printer and select CANCEL ALL DOCUMENTS, depending on your operating system. This should clear the queue.
E. If the status states: USE PRINTER OFFLINE, right-click on the Brother printer and select USE PRINTER ONLINE depending on your operating system. This should set the printer driver ONLINE.
F. If the status states: PAUSED, right-click on the Brother printer and uncheck PAUSE PRINTING. This should allow the printer to resume printing.
G. If the status is ready and no documents are in the queue, attempt to print the Windows test page. If not successful, verify the selected port. If USB is the selected port follow step 4. If USB is not selected,change the port to USB, then attempt to print the Windows test page. If not successful proceed to step 4.
4. Turn the printer OFF.
5. Close any open programs.
6. Click Start, Run, type: control printers
7. Right click Printer, left click Cancel All Documents (if available). Confirm if necessary (click OK).
8. Right click Printer, left click Delete. Confirm if necessary (click OK).
9. Left click File menu, left click Server Properties, left click Driver tab, left click print model name, left click Remove button, click Confirm.
10. Close the Print Server Properties window to return Printers and Faxes window.
11. Check that the USB cable is properly connected at both ends.
12. Turn the printer ON.
13. Wait until printer has ready light or green status, watch the Printers and Faxes window to see if printer is automatically reinstalled.
14.a. If printer was automatically reinstalled, right click Printer icon, left click Properties, left click Print Test Page button. If the printer is not automatically reinstalled, call Brother Customer Service at 1-877-Brother (1-877-276-8437).
b. If printer was not automatically reinstalled, try a new USB cable. Ifthe printer still is unable to print, call Brother Customer Service at1-877-Brother (1-877-276-8437).
Nov 02, 2010 | Brother HL-5270DN Laser Printer
Mp250 canon user intervention required problem
Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Office Equipment & Supplies
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
Was printing fine but now when I send something to print, the printer doesn't respond at all and just shows the "ready" screen
Is it connected directly to your PC, or is it networked?
In your printer dialog box, does the printer say "ready"? it may be "Paused" or "offline". Right click and select "resume Printing", and/or "use printer online"
Are you sure the cable is still connected and working?
try removing and reinstalling driver.
Mar 11, 2009 | HP LaserJet 3600n Printer
Printer won't print
Make sure the ready light is on. Press the green go button.
Also make sure you don't have printing paused.
CONTROL PANEL
PRINTERS AND FAXES
DOUBLE CLICK ON YOUR KYOCERA PRINTER DRIVER
CLICK FILE
IF THERE IS A TICK NEXT TO PAUSE PRINTING, THEN CLICK ON PAUSE PRINTING
IF NOT THEN DON'T.
ALSO MAKE SURE YOUR PRINTER IS SET TO DEFAULT PRINTING DEVICE.
If all else fails, install the kyocera fs-1700 driver for the printer. it's a generic driver for kyocera-mita.
Oct 28, 2008 | Kyocera FS-2000D Laser Printer
HP Officejet H470 InkJet Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
