Question about RTO Bernzomatic Brushed Nickel Patio Heater
It won't lit. i can hear the ignition pop but the fire doesn't start
    Top Expert:
  • RTO Master
  • 8,177 Answers
If ignitor sparking check gas flow
Posted on Jan 13, 2018
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Won't start
Check alternator fuse , it's should be a high amp fuse . Question is did you give some one a jumb start , this could happen , another thing to check is your ignition fuse and your ignition switch , but first check all fuses . Including the big once under the hood and inside the car . Good luck and I hope this helps
Jan 15, 2013 | Cars & Trucks
Mod 417.94052500 won't heat
Have you tried to watch or listen to see if you hear it ignite and then it goes out or does it not try to ignite at all?
If it doesn't try to ignite at all, replace the igniter with this part.
If it ignites and goes out after a few seconds, replace the flame sensor with this part.
Oct 19, 2012 | Kenmore 77632 Gas Dryer
I have a 92 mustang lx 2.3 and it won't start. There is no fire at the plugs, and I can't hear the fuel pump kick on. The reset on the fuel pump is not popped out, so it is good. Any help woul
I would check the EEC relay and the fuel pump relay for power and ground signals first. Both circuits are controlled by the ignition key switch. The fuel pump should be powered for 3 seconds when you turn the key on.
Sep 29, 2012 | 1992 Ford Mustang
Car won't start
doesn't fire??? you should check your battery, if it is fine, you can check the starter and ignition.
car diagnostic tool
Aug 17, 2012 | 1988 Volvo 760
2006 dodge stratus won't crank and cruise control won't light
Must not have been much of a mechanic. If the engine runs and sounds fine sometimes and other times it doesn't then it does not sound like a mechanical problem with the engine. Sounds more like a issue with either the ignition system or fuel system.
Feb 20, 2018 | 2006 Dodge Stratus
GMC 2000 sierra pick up 1500 sounds like it wants to start but won't turn over. Battery sounds good so I guess battery and alternator are ok. For several years fuel gauge doesn't work and...
It sure could be. But, first...by "won't turn over" you do mean it cranks at normal speed but won't start?
A simple test of the fuel pump is to stand by tank and listen as someone turns key to on. When first turned to on, your pump will activate for 2 or 3 seconds, pressurizing the fuel system, and then shut off if the engine computer doesn't get a cranking signal. Do you hear it come on? If not, then something's not turning your pump on. If you can hear it buzz on briefly, then maybe it's your filter. Another test: Spray a little starting fluid into your intake manifold (remove the big hose going into intake manifold) while someone tries starting it.If it doesn't fire and try to stay running, then it's probably an ignition problem. But if it does fire off, then you know it's a fuel problem-likely your pump or filter. good luck.
Nov 07, 2011 | 2000 GMC Sierra
2 problems! Sometimes the lower oven doesn't start. U can hear the motor humming kinda but when I spin the blower wheel it'll start up and ignite. I've tested the capacitor and good. Any idea?...
I am not sure how you tested the capacitor but your issue is a classic one for a bad capacitor. The second problem is not very clear. With that being said, the wire could be grounding somewhere other than the ignitor. Please clarify a little more and I will help you work thru this.
Jun 22, 2017 | Blodgett DFG200 Stainless Steel Gas Double...
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
Apr 12, 2009 | Dryers
RTO Bernzomatic Brushed Nickel Patio Heater Logo
99 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
